Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Monitor Audio RX6 and SVS Combination
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="KenMasters" data-source="post: 713820" data-attributes="member: 517"><p>If you have multiple subsevenly dispersed as to negate localisation, you can benefit from setting the crossover higher, depends on what gives you the smoothest handover from speaker to sub. Worthwhile measuring a range of crossover points.</p></blockquote><p></p>
[QUOTE="KenMasters, post: 713820, member: 517"] If you have multiple subsevenly dispersed as to negate localisation, you can benefit from setting the crossover higher, depends on what gives you the smoothest handover from speaker to sub. Worthwhile measuring a range of crossover points. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
