Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Little Bear P1 Power Supply
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="fredeb" data-source="post: 978764" data-attributes="member: 13623"><p>DC power supplies usually have + inside - outside .</p><p></p><p>24VDC is correct , 2A at least , 3A or more , even better .</p><p></p><p>If you have a multi-meter , you can check for continuity on the board socket to be sure of polarity .</p><p></p><p></p><p>Some specs , incl. psu spec : <a href="http://www.audiocostruzioni.com/r_s/pre/little-bear-p1/little-bear-p1.htm" target="_blank">http://www.audiocostruzioni.com/r_s/pre/little-bear-p1/little-bear-p1.htm</a></p></blockquote><p></p>
[QUOTE="fredeb, post: 978764, member: 13623"] DC power supplies usually have + inside - outside . 24VDC is correct , 2A at least , 3A or more , even better . If you have a multi-meter , you can check for continuity on the board socket to be sure of polarity . Some specs , incl. psu spec : [url=http://www.audiocostruzioni.com/r_s/pre/little-bear-p1/little-bear-p1.htm]http://www.audiocostruzioni.com/r_s/pre/little-bear-p1/little-bear-p1.htm[/url] [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
