Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
How to sound-proof a room (for medi-educational purposes)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Norval" data-source="post: 38867" data-attributes="member: 62"><p>Seal door completely, solid door is better than hollow core, and there must be no air leaks - not even a key hole. Same with windows (sealed). Seal the sealing where it meats the walls using building foam. And thick Pink Airolite in the ceiling works. A second false sealing below the actual ceiling butwith as little contact to the first as possible will helps even more.</p><p></p><p>With the brick walls we have in SA that's already quite good. But if you need even more you have to build a "floating" room within your current room. Again with as little physical contact with the actual walls as possible.</p><p></p><p>Most important is however to seal the door, windows and roof</p><p></p><p>Here's my door and weights a hefty 70kg ;D</p><p></p><p>http://www.avforums.co.za/index.php/topic,1622.0.html</p></blockquote><p></p>
[QUOTE="Norval, post: 38867, member: 62"] Seal door completely, solid door is better than hollow core, and there must be no air leaks - not even a key hole. Same with windows (sealed). Seal the sealing where it meats the walls using building foam. And thick Pink Airolite in the ceiling works. A second false sealing below the actual ceiling butwith as little contact to the first as possible will helps even more. With the brick walls we have in SA that's already quite good. But if you need even more you have to build a "floating" room within your current room. Again with as little physical contact with the actual walls as possible. Most important is however to seal the door, windows and roof Here's my door and weights a hefty 70kg ;D http://www.avforums.co.za/index.php/topic,1622.0.html [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
