Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Audio Visual Technology
HOW MUCH DO POWER AMPS COLOUR SOUND?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="chipwelder" data-source="post: 96256" data-attributes="member: 54"><p>I think the higher end you go, the more the designers take on what makes good sound tends to get into the product, lower down it is just the best technical solution at the price...</p></blockquote><p></p>
[QUOTE="chipwelder, post: 96256, member: 54"] I think the higher end you go, the more the designers take on what makes good sound tends to get into the product, lower down it is just the best technical solution at the price... [/QUOTE]
Insert quotes…
Verification
Post reply
