Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
help with project
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JimGore" data-source="post: 810998" data-attributes="member: 3"><p>I don't think you will be able to do this very easily. The analogue parts aren't normally too bad, but the digital can be tricky. USB communications normally go through a dedicated comms chip, which is sometimes internal to a microprocessor which in turn will do all kinds of others tasks like handling the LCD display, buttons, etc as well. Then you have the actual decoding and conversion to analogue, etc on top of that.</p><p></p><p>The only real way to do it is to 100% understand the circuitry you have there then make an informed decision about what where and how.</p><p></p><p>It will most likely be far easier to just rebuild it all without trying to harvest the bits (or put it in the bin and save your bucks then buy what you want).</p><p></p><p>Kind regards,</p><p>Ian.</p></blockquote><p></p>
[QUOTE="JimGore, post: 810998, member: 3"] I don't think you will be able to do this very easily. The analogue parts aren't normally too bad, but the digital can be tricky. USB communications normally go through a dedicated comms chip, which is sometimes internal to a microprocessor which in turn will do all kinds of others tasks like handling the LCD display, buttons, etc as well. Then you have the actual decoding and conversion to analogue, etc on top of that. The only real way to do it is to 100% understand the circuitry you have there then make an informed decision about what where and how. It will most likely be far easier to just rebuild it all without trying to harvest the bits (or put it in the bin and save your bucks then buy what you want). Kind regards, Ian. [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
help with project
