Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Cable Talk
Help in identifying my cables
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="user 1447" data-source="post: 1066886" data-attributes="member: 1447"><p>on speaker cable - the only time i believe in directionality is when you have one of those cables with a box inbetween like the transparent (brand) or MIT ones which are reputed to generally be zobel impedance networks </p><p></p><p>generally though for aesthetics when the arrows are visible i just follow the direction of the arrows - i mean if the arrows are seen then having them pointing in the wrong direction just "looks" pretty clueless even if it doesn't sound different <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite27" alt=":giggle:" title="Giggle :giggle:" loading="lazy" data-shortname=":giggle:" /></p><p></p><p>if there are no arrows visible on the sheath - just plump them on in any direction and bobs your uncle</p></blockquote><p></p>
[QUOTE="user 1447, post: 1066886, member: 1447"] on speaker cable - the only time i believe in directionality is when you have one of those cables with a box inbetween like the transparent (brand) or MIT ones which are reputed to generally be zobel impedance networks generally though for aesthetics when the arrows are visible i just follow the direction of the arrows - i mean if the arrows are seen then having them pointing in the wrong direction just "looks" pretty clueless even if it doesn't sound different :giggle: if there are no arrows visible on the sheath - just plump them on in any direction and bobs your uncle [/QUOTE]
Insert quotes…
Verification
Post reply
Cable Talk
