Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Valves / Vacuum Tubes
Help identifying valve please .
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ampdog" data-source="post: 769056" data-attributes="member: 144"><p>If pin 9 goes to an internal shield between the triodes, it is an ECC85/ECC88 type valve. 12A*7 types do not have internal shields. </p><p></p><p>From the shape of the anodes I would guess ECC85 type or Russian equivalent (ECC88 and similar has frame-grid construction and typical inward 'dent' in the anode to bring it quite close to the cathode.)</p></blockquote><p></p>
[QUOTE="Ampdog, post: 769056, member: 144"] If pin 9 goes to an internal shield between the triodes, it is an ECC85/ECC88 type valve. 12A*7 types do not have internal shields. From the shape of the anodes I would guess ECC85 type or Russian equivalent (ECC88 and similar has frame-grid construction and typical inward 'dent' in the anode to bring it quite close to the cathode.) [/QUOTE]
Insert quotes…
Verification
Post reply
