Hi
Does it make a difference what thickness electrical cables inside an amp are? I found many threads for speaker and other cables, but for the electrics inside.
Specifically, the DC side of a SPSU to the amps. I have normal 1.5mm black and red cabling used in a house, but the copper strands are thicker than normal electrical wire on the AC side.
Is this OK, or should I use the thinner copper strand cable? Does it make a difference?
Sent from my SM-N950F using Tapatalk
