Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Clicking noise on speaker when changing volume
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ara" data-source="post: 63622" data-attributes="member: 1336"><p>So the noise stopped just as suddenly as it started. The next morning when I switched the amp on the clicking noise was gone. I ramped the volume up and down and there was no clicking noise.</p><p></p><p>I now have another question on clipping and specifically the CA 840A clipping detection. When trying to see whether the noise is still I really turned up the amps volume to test (never need to go that high but I just wanted to see). When the volume was on -15 the amp warned about clipping. The amp is rated at:</p><p>120W RMS into 8 Ohms</p><p>200W RMS into 4 Ohms</p><p></p><p>and the speakers (Quad 22L2) is rated at</p><p>150W and is 6 Ohms</p><p></p><p>Is this amp to "small" for the speakers if you want to really put the volume up? What is causing the clipping warning as there is no sound distortion, popping noise or anything that you can hear? Just want to fully understand this as I don't use that high volume levels ever.</p></blockquote><p></p>
[QUOTE="ara, post: 63622, member: 1336"] So the noise stopped just as suddenly as it started. The next morning when I switched the amp on the clicking noise was gone. I ramped the volume up and down and there was no clicking noise. I now have another question on clipping and specifically the CA 840A clipping detection. When trying to see whether the noise is still I really turned up the amps volume to test (never need to go that high but I just wanted to see). When the volume was on -15 the amp warned about clipping. The amp is rated at: 120W RMS into 8 Ohms 200W RMS into 4 Ohms and the speakers (Quad 22L2) is rated at 150W and is 6 Ohms Is this amp to "small" for the speakers if you want to really put the volume up? What is causing the clipping warning as there is no sound distortion, popping noise or anything that you can hear? Just want to fully understand this as I don't use that high volume levels ever. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
