Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Building a system piece-by-piece
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Scrat" data-source="post: 19752" data-attributes="member: 561"><p>I was actually wondering if I shouldn't go for some standmounters, thanks for the tip Norval! I think you're right, and budget-wise, I think I could get more bang for my buck? I'm planning on building two systems - one for the lounge, and one for the bedroom. So this way I could use the standmounts as mains for now, and upgrade to floorstands later, move the standmounts into the bedroom, and voila!</p><p></p><p>Capetonian, thanks for the link, I will most definitely use that information. It's what I've been looking for, but I've been trawling different sites, and that hasn't helped me much.</p></blockquote><p></p>
[QUOTE="Scrat, post: 19752, member: 561"] I was actually wondering if I shouldn't go for some standmounters, thanks for the tip Norval! I think you're right, and budget-wise, I think I could get more bang for my buck? I'm planning on building two systems - one for the lounge, and one for the bedroom. So this way I could use the standmounts as mains for now, and upgrade to floorstands later, move the standmounts into the bedroom, and voila! Capetonian, thanks for the link, I will most definitely use that information. It's what I've been looking for, but I've been trawling different sites, and that hasn't helped me much. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
