Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Audio Visual Technology
Audio Formats, whats best? (DTS-HD, TrueHD, etc.)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Robert_E" data-source="post: 67383" data-attributes="member: 853"><p>On a THX receiver and probably most others 0dB would be Dolby Reference level for the mix. So if you have to 'crank it up' to -5 it's the way the audio was mastered intentionally. Usually in movies where you've got to put the levels up to -10dB ++ (I find) for proper dialogue volume are the ones that feature the building shaking dynamic range/bass/explosions later in the movie <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="Robert_E, post: 67383, member: 853"] On a THX receiver and probably most others 0dB would be Dolby Reference level for the mix. So if you have to 'crank it up' to -5 it's the way the audio was mastered intentionally. Usually in movies where you've got to put the levels up to -10dB ++ (I find) for proper dialogue volume are the ones that feature the building shaking dynamic range/bass/explosions later in the movie :) [/QUOTE]
Insert quotes…
Verification
Post reply
