Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Valves / Vacuum Tubes
Advice : Valve power amp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ampdog" data-source="post: 889984" data-attributes="member: 144"><p>or if it is made sure that heater voltage values do not exceed the rated figure by more than a few percent. In some modern instruments one will easily find voltages of around 7,2Vac or higher on e.g. 6.3V heaters.</p></blockquote><p></p>
[QUOTE="Ampdog, post: 889984, member: 144"] or if it is made sure that heater voltage values do not exceed the rated figure by more than a few percent. In some modern instruments one will easily find voltages of around 7,2Vac or higher on e.g. 6.3V heaters. [/QUOTE]
Insert quotes…
Verification
Post reply
