Author Topic: Question : Router to gigabit Hub connection  (Read 686 times)
Offline CAD
  • Trade Count: (+88)
  • Total likes: 250
« on: October 16, 2021, 07:15:39 PM »
Hello chaps.
My set up has a 100mbs router which connects via cat6 to a gigabit hub/switch and from there to the TV/other devices via cat6
It's a cheapie TPlink which I got when I had the fiber installed here. It does the job but damn 4K movies buffer and I dont recall having that issue on my older Acher D7 router set up in the old place.
As I understand it the router will take care of all the traffic so I was wondering if the 100mbs router would do so effectively  :thinking:
Offline Orcish75
Re: Question : Router to gigabit Hub connection
« Reply #1 on: October 17, 2021, 10:34:38 AM »
Unfortunately a lot of the entry level routers don't have a very powerful cpu in them so they can't keep up with 100Mbps when applying all the firewall rules, routing tables etc to the traffic.
Definitely worthwhile getting a decent gigabit router if you're going to be doing 4k streaming and if at all possible, keep it all wired, don't do 4k streaming over wifi.
Something interesting I came across the other day when I upgraded my fibre to 100Mbps. I'm using an old PC for my router and it had a 100Mbps network card on the WAN side. I was getting approx 95Mbps up and down on the Speedtest. I changed the network card on the WAN side to a gigabit card and was then getting approx 105Mbps up and down, so I think the fibre links are a bit faster than what they actually advertise.
  • Trade Count: (+180)
  • Total likes: 1101
  • Condition your mains to condition your ears
« Reply #2 on: October 17, 2021, 11:13:51 AM »
Consider the TP_Link AC1200 - you can get them at about R1500 or less
TP-Link AC1200 Dual-Band Wi-Fi Gigabit Router
Specifications
Broadcom
802.11ac/a/b/g/n
867Mbps at 5GHz + 300Mbps at 2.4GHz
5 Gigabit Ports
1 USB 2.0
3 fixed antennas
VPN Server
IPv6 Ready
Tether App
Offline CAD
  • Total likes: 250
« Reply #3 on: October 17, 2021, 01:44:25 PM »
Figured as much thanks bud ,and I sold my TP-Link Archer D7 AC1750 not too long ago  :facepalm:
I do have all my end points wired as well.
Thanks gents
Offline Orcish75
« Reply #4 on: October 17, 2021, 09:27:30 PM »
Ah, pity! As that is a decent router.
One other thing you can check is the MTU setting on your router, the better routers can set this automatically. If it's too high, it'll fragment the packets and waste a lot of your available bandwidth. If your fibre account is a PPPoE account (you need to put in a username and password into your router) then your MTU should normally be set to 1492.
Use this link to determine your optimal MTU setting:
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Offline Gohde
« Reply #5 on: October 18, 2021, 07:05:56 AM »
I run Ubiquiti EdgeRouter, PoE Switch and AC Access Point combo. Almost like a 3 component Hifi vs Network Integrated.  ;D
I had more wired endpoints than ports in the router and itís all tucked away in a cupboard with out the little white disc of the AP in the house. No little table with a router somewhere which has cables hanging out. And it makes incremental upgrades easier. I get 180mbits on wireless, but if thereís a point where I want more, I just need better AP with the wired connection still having a lot of headroom.
