Author Topic: FreeNAS 7 and HP Microserver (1000baseTX issues ?)  (Read 2013 times)
Offline jaxx
« on: May 30, 2011, 11:10:42 AM »
Hi,
Im just checking to see if anyone else running FreeNAS 7 on the HP microserver is experiencing problems connecting via gigabit Ethernet ?
My server seems to default to 100BaseTX full-duplex if I leave it on autoselect. When I try to force the interface to 1000BaseTX full duplex, I loose the ethernet connection.
Ive tried this both via the GUI, and using IFCONFIG.
My switch is a Dlink DGS-1005D ( which supports 1000BaseTX), and Ive tried different CAT5e cables. BTW, I have other devices on the same switch, which connects with gigabit.
Anyone having a similar experience ?
Offline fdlsys
  • Vinylist, DIYer
  • Trade Count: (+99)
  • Total likes: 563
Re: FreeNAS 7 and HP Microserver (1000baseTX issues ?)
« Reply #1 on: May 30, 2011, 12:19:37 PM »
Nope, mine connects at a gig just fine.
I have other problems - the eth0 connection drops once in a  blue moon, causing havoc with my various clients, etc. Eth0 goes Down, and luckily, goes back Up automatically.
No idea what's causing it...
Offline ara
« Reply #2 on: May 30, 2011, 12:25:49 PM »
No problem either with the same switch.
Offline jaxx
« Reply #3 on: May 30, 2011, 01:07:07 PM »
Thanks for the responses... at least I know that it 'should' work.
Offline jaxx
« Reply #4 on: May 31, 2011, 08:58:24 AM »
Update :
Tried a 3rd cable, and it connects fine on 1000baseTX.
Seems to have been the cables, though they are all CAT5e - need a new cable supplier :)
Offline spike_za
« Reply #5 on: May 31, 2011, 03:31:51 PM »
are you using prebuilt patch leads or a diy job
Offline jaxx
« Reply #6 on: May 31, 2011, 04:46:02 PM »
Hi,
These are those 'made while you wait' cables.
Im gonna stick to the pre-made type from now.
Offline spike_za
« Reply #7 on: June 01, 2011, 09:55:28 AM »
Yeah the problem is alot of those cables are made with solid cables instead of stranded
Offline Rotten Johnny
« Reply #8 on: June 01, 2011, 10:03:23 AM »
Roll your own, there's nothing to it.
