TO NONE of the above posters....Man, samples ? Controlled situations ? All the "clever" BS. Double blind tests. Any of you working for NASA or MIT ? All just crap to hide peoples inabilities to listen properly of deficiency's in their hearing, or the system under scrutiny. Yea I said it DEFICIENCIES in their HEARING!
And the blown up doll between the ears that is called the EGO.
Sit your butt down, simply change the cables and use the TWO most amazing instrument you have....your EARS!! Stuff Placebo! There is no Placebo involved if you can afford only R5k. For once forget about EVERYTHING and answer this damn simple question!
DID I HEAR A DIFFERENCE ?
DO I LIKE IT ?
IS MY SYSTEM SOUNDING BETTER OR WORSE ?
My God, the opinions and back and forth on this forum is like Democrats and Republicans ?
Can ANY person offer an opinion without running to a GURU, God, some wisearse salesman, YOUTUBE, the God GOOGLE ? Are the people so DUMB to NOT form their OWN opinion ?
Did the CD make my system better ? Yes, Can I afford it ? Yes, then buy the thing. Not better, walk ON, explore more. My God, is that so difficult ? If not, do you now advocate CD Players makes no difference ?
Did the sound change positive/negative when I replaced my speaker cable ? No, then walk ON, case closed. But dont now become an EXPERT and say cables makes no difference!?
Gosh that Snake Oil Francois says cables DO make a difference....Gosh he is talking crap, then go there and LISTEN...
then offer the opinion: I(ME), did/didnt hear a difference. FULLSTOP. Dont climb on your "mishoop"
and cry to the world: "CABLES MAKES NO DIFFERENCE". "ALL AMP SOUND THE SAME". "HORNS ARE THE ONLY REAL SPEAKER".
or worse: "I WAS WRONG, THAT xxx MADE SUCH A DIFFERENCE"...the most difficult word for a human being to utter....
99% of the people, ME INCLUDED on this forum, dont have a fricking idea about the science in and around our hobby, Yeah so Im an indeed Electronic Engineer, but I STILL cant make up an ORIGINAL new design like Williamson, Nelson Pass, Koetsu or Wilson and SCHALK HAVENGA! That cheat John Nouwens ? Remember his amps ? Everybody goes Ooooooh, to a circuit from a 1964 book.... I checked yesterday, google EL84, EL34 schematics. HUNDREDS, and all basically the same....tweak here and there....
Any of you found a DIFFERENT way to build a class AB ? To strap in a Triode valve ? Use a 1940 radio valve in some for of small gain preamp ? Yeah we all "design" our output transformers according to a piece of software somebody ELSE wrote
, we "pick" out valves according to the manual
Stop being CLEVA and listen. Man up and seek your OWN audio nirvana. Even if it means putting pebbles on you DAC for clarity
