Author Topic: Which cooler for i5 2500K?  (Read 2019 times)
Offline johnc
  • Total likes: 0
  • It's only rubbish until you need it.
« on: May 27, 2011, 07:00:07 PM »
I'm somewhat overwhelmed by the sheer range of CPU coolers available out there.
This CPU will probably sit on an Asus P67 pro motherboard.
What is the most effective cooler available for the 2500K for < R500 ?
Go to the centre of the gravity's pull, and find your planet you will.
Offline Skeeter
Re: Which cooler for i5 2500K?
« Reply #1 on: May 27, 2011, 07:46:18 PM »
I urge you to take your questions here: http://www.phforums.co.za/f14/
Offline LAV
« Reply #2 on: May 27, 2011, 10:40:28 PM »
The std. Intel heatsink & fan assembly. This CPU does not run hot.
Vaal Triangle (Southern Gauteng)
Offline Strainger
« Reply #3 on: May 28, 2011, 12:51:16 AM »
Johnc
Myself running 2500k with Coolermaster Hyper 212. Idles at 18, seldom goes above 45C.
Also very quiet, has option to add additional 120mm fan on exhaust side. Not needed imo though.
Cost in region of R250 to R300. Got mine from LandmarkPC.
Offline kamikazi
« Reply #4 on: May 28, 2011, 02:35:29 PM »
From what I've heard with the new CPUs you should be fine with the stock cooler. Otherwise I'll always recommend Zalman's CPU coolers, not sure whether they have products for socket 1155 out there yet?
Offline dotVIBE
« Reply #5 on: May 28, 2011, 05:48:56 PM »
Hyper 212 is a good call.
Town of the Cape
Offline johnc
  • Total likes: 0
« Reply #6 on: May 28, 2011, 09:49:32 PM »
Thanks for the info. Agreed, the 212 looks like a good choice.
I also read that the stock cooler is fine.
Are CPU's generally supplied with a cooler included or does one have to buy the cooler separately?
Offline Robert_E
« Reply #7 on: May 28, 2011, 10:06:06 PM »
CPU's sold through retail come boxed with a fan
