Author Topic: Some methods to prevent your laptop (and desktop) from overheating  (Read 2638 times)
Offline Zilch
  • Weet nie
  • Trade Count: (+26)
  • Total likes: 170
  • ... never finishing projects
« on: September 07, 2021, 03:10:56 PM »
As a computer enthusiast, I would like to present to the community three different methods of improving thermals on your computer.
Everyone knows that most manufacturers like to go the cheap route. We are in a very competitive market, and whomever has the best price to performance/value ratio will win. That said, some of us value a product that will last us some amount of time. For example, most laptops (even MacBook's) have a standard warranty of one year, meaning that if something does wrong even so much as a day after the original purchase date, you might be stuffed.
Other companies - like Dell - have a very good warranty on some of their computers. My Dell Latitude 5290 came with a four year warranty, which to my 19 year old mind is incredible!
But, as you will see, there are many methods to improving the thermals on your laptop. The first one will be the easiest, because it only requires you to change one setting in the BIOS...
     1. Disable Intel Turbo Boost Technology...​
This one will make an unbelievable difference in the thermals of your laptop. Do note that this is only needed on a modern laptop (post 2015-ish), as that is roughly the time when manufacturers started prioritizing form over function; when laptop manufacturers started being 'okay' with CPU thermals over 90℃. Older CPU's also don't have Turbo Boost, so probably look up your CPU model before spending time going through your BIOS.
As stated, this WILL differ from laptop to laptop, even if they are from the same manufacturer, generation, or even product line. You have been warned!
Please see the following two pictures for the difference this can make (click to enlarge)...
As one can plainly see, the first is before, and the second is after disabling Turbo Boost. Naturally, you will lose a tiny bit of performance, but if you have an M.2 SSD (as I do) then the difference will be even less noticeable. These tests were done on my personal laptop, and I will definitely keep it disabled as I find zero performance losses.
     2. Clean your 'radiator'....​
This one can also make a good improvement on thermals, but it will depend greatly on the environment where the laptop was used, where it was placed, and how old it is. The way computers work is you have a copper pipe with a metal block at one end and a radiator at the other end. The goal here is simply to transfer the heat from the CPU to the radiator, and then the radiator will dissipate the heat into the air. Naturally, for this to work well you need an intake fan to suck air into the laptop and blow it right out through the radiator.
The easiest method could be to use a compressor and blow it into the exhaust, but that would be retarded because the dust would still be inside the laptop. This is obviously undesired as in some cases a large buildup of dust could short a signal on the motherboard, and also build up even more heat. It also doesn't help that the compressor starts to spin the fan at a few thousand RPM's, because that has a good chance of sending a voltage to the regulator (a device that regulates the voltage) and destroys it.
The proper method would simply be to disassemble the bottom part of the laptop chassis, and use a compressor, toothbrush, and cloth to clean it out. While you're there, you might as well follow the next step.
     3. Replace the old thermal compound...​
In some cases this would not make a big difference at all. Improvements might be as low as 2-3℃, or up to 10-15℃. It largely depends on the age of the laptop, and the quality of the thermal compound the manufacturer used.
When replacing it, you have to be very, very careful not to chip the CPU die of the laptop. This happened to me once when I was 15 or 16 when I got a pretty sweet Dell Vostro (red with Intel i7 and Nvidia GPU), and I replaced the thermal compound only to have a machine that partially worked. This can be an overwhelming pain in the dick if done incorrectly.
     Aftershow. Now here is the fun part, where I tell you a story of a laptop that I had fixed up for a friend...​
She had an old Sony laptop, with a 1st gen Core i5, 4gb RAM, and a 5400RPM mechanical drive. I upgraded the RAM to Crucial 8GB dual channel, fitted it with a 512GB WD Blue 2.5" SSD, and loaded it with Windows 10. Naturally, she was quite happy, but that was quite hard when the laptop burnt her lap (first and last time she did that). Anyway, the laptop reached a high of almost 80℃, which is stupid hot for something as old as that.
Now you might think that 80℃ on the CPU would not be nearly enough to burn someone, I mean those laptops where probably extra thick for a reason. WRONG! The laptop's bottom plastic piece was covered in an Aluminium sheet, most likely to reduce EMI from messing with the RAM and core components. But in any case that Aluminium got very, very hot. So I did the obvious.
First I cleaned the radiator by removing it (carefully), and using the compressor to blow air through the exhaust. I also used an old toothbrush to get to the small parts and to ensure all the dust was out. Next I replaced the thermal compound.
The result was that the CPU ran 13-15℃ cooler (when maxed out with AIDA64). This means that the machine now easily gets an additional five years (at least) of reliable service, and will work great and fast in that time period.
Hope this helps anyone looking to do something similar :dop:
If you don't understand the difference between "their", " there" and "they're" then your a idiot.
  • Trade Count: (+180)
  • Total likes: 1107
  • Condition your mains to condition your ears
Re: Some methods to prevent your laptop (and desktop) from overheating
« Reply #1 on: September 07, 2021, 03:54:34 PM »
I had a laptop that got so hot it smelled
I used USB fan built into a tray and sat the laptop on top.   It didn't smell too bad after that
Offline kamikazi
« Reply #2 on: September 07, 2021, 04:18:43 PM »
One of the best ways to reduce overheating is to look at Intel XTU (extreme tuning) and undervolting your CPU. Note, that I think this might have been disabled for newer Intel CPUs, but this is a very effective way of boosting performance and lowering heat. On my Thinkpad Workstation laptop (which doesn't throttle the processor) but runs at quite a hot temperature you can shave off 10-15C by undervolting by 100mV. if you have a desktop system you can also look at voltage adjustments through the Bios, but in my experience, it's always better to invest in a good air cooler for maintaining good performance (I don't buy closed loop radiator coolers though since the pumps are noisy and there important installation considerations that could impact reliability so it is very dependent on the chassis), but even for low profile there are some seriously impressive air coolers around.
Disabling turbo boost can also work, but you will be heavily impacting performance. On laptops with poor thermals, you will have throttling in any event and disabling speed step might only mean a couple of Hertz difference since you are already operating close at thermal limits. So there is more downside and less upside from this compared to undervolting.
Repasting your CPU with a good quality thermal paste is also highly recommended as suggested, but not recommended if you don't have good DIY skills or are comfortable disassembling electronic stuff and it could potentially void your warranty.
« Last Edit: September 07, 2021, 04:25:32 PM by kamikazi »
Offline Zilch
  • Weet nie
  • Total likes: 170
« Reply #3 on: September 07, 2021, 04:28:20 PM »
If anyone is confused, this video will explain things a lot better than I can :giggle:
https://youtu.be/d_H054zwCOY
