Author Topic: The HiFiMan HE6SE v2 Journey  (Read 1128 times)
Offline Wolvebain
« on: August 26, 2021, 09:41:49 PM »
Hey all,
inspired by @Scubadude , I have listed my journey so far with the HiFiMan HE6SE...
The motivation for getting these headies was to both evaluate the power demands of them, as well as their tone/signature as a stepping-stone towards the hailed HiFiMan Susvara. (many people have rated a modded HE6SE as a the Susvara-Jnr)
The stock headie
When I got them, I was SERIOUSLY underwhelmed!!  The cable was just AWFUL!!! Screamed low-grade build, that one sometimes get from wish.com  :(
The sound was...... interesting...
My initial impression was as follows
  • Un-EQ'd, they have provide a great sound stage, but like the HD800/S the simulated sound-stage seems to comes at the cost of bass depth and texture.
    • Highs can be peaky, part and parcel of that simulated sound stage I guess.
    • Mids and vocals are really awesome.  The tone and timbre fantastic.
  • EQ'd they are awesome.
    • Bass is not anemic, and has some (not a lot) of sub-bass rumble.
    • Upper-bass and Mid-bass needs more definition though. Perhaps pads can help, or more power/current?
    • EQ does help the peaky highs as well,  and leaves the fantastic mids largely untouched.
  • it is a power hog.   Even though I have some clicks left on the HA-6A HPA,  it does get muddy past the 3 o'clock mark (both XLR and RCA)
  • Headband definitely needs improvement / upgrade.
  • Earpads are really awful. Too soft. With the headband combination, they don't feel like a proper fit and seal.
  • They can easily be a replacement for the HD650 as my daily driver IF I can get the seal and / or driving power resolved.
  • Right now,  ballad and folk music should pretty great.. Hard Rock, Metal, Prog, etc. sounds mediocre
The First Tweak/Upgrade:
The first upgrade was bending the headband to make it tighter, for improving the clamping force.
This was an easy task, but even with the additional clamping force, the weight of the earcups, the headband and stock earpads made it difficult to both form a great seal, and stay in position when bopping my head to music.
But, still an improvement none the less!
The Earpad Upgrade:
I had already ordered replacement aftermarket Dekoni Elite Sheepskin earpads before the headies arrived, based on what others' experience and suggestions.
Much better seal and helps prevented the headie from moving when bopping my head.However, these are not as plush as I'd like, so I am still considering other earpads (like the Kennerton ECL-01 or ECL-02)Sound felt better as well... better bass control, impact, and attack.  This was prolly a combination of the burn-in and the earpads.
A bit improvement at the end of the day  :thumbs:
The Grill Mod/Upgrade:
Sadly, the honey-comb grills were not available, so I decided to DIY my own grills.Source a cheapo metal mesh magazine case to cut my own custom grills
Sadly, the display unit was not the same as the box model.  The one I had purchased had indented wave/patterns
Took a bit of finesse, but manage to flatten it a bit.  However, decided to incorporate some of the indented lines into the grill; kept the line crease caused by the indent and aligned it to run in parallel vertically.
One can see this in a specific angle, but can definitely feel it on the grills.Sound stage improved to un-EQ'd levels, without impacting the sound sig negatively  :2thumbs: Just received my matched pair of Shuguang Natural Sound KT88-T tubes today, and a huge improvement to the driving power, attack, and dynamics of the HE6SE! :groovy: Still tho, think a Schiit Ragnarok 2 would have been ideal (but Schiit don't want to sell to SA)
The Next Mod/Upgrade:
Managed to source an Audeze headband, yoke, yoke-rod kit.Waiting for it to arrive.
A man can be destroyed but not defeated
Offline Wolvebain
Re: The HiFiMan HE6SE v2 Journey
« Reply #1 on: August 26, 2021, 09:53:12 PM »
The cable in the pics are my DIY Litz cable.
The stock cable is just too awful to show anyone
Online naughty
« Reply #2 on: August 26, 2021, 10:54:34 PM »
Grille mod looks amazing - I'm sure it sounds amazing too  :thumbs:
Offline kamikazi
« Reply #3 on: August 27, 2021, 11:11:06 AM »
Have you tried these with a speaker amplifier with an adapter yet? I'm not sure how these compare to the original HE-6 efficiency wise, but if you haven't tried them on a high quality speaker amplifier, you are very likely missing out. Since you said metal and prog is not sounding great with these, I'd definitely think that have a power problem, these headphones should literary "grab music by the balls" and shake things up if well amped.
If you are looking for plusher more angled pads (these help with staging too) you can check out Defean pads on Amazon. I bought some for my HE-500 and they were a nice upgrade from the stock focus pads from Hifiman that fell apart.
Offline neilh
« Reply #4 on: August 27, 2021, 12:04:28 PM »
Amazeballs
With regards to the Schiit, you tried a service like Postbox Courier? Not cheap at all, but fast and efficient
Offline Wolvebain
« Reply #5 on: August 27, 2021, 07:40:25 PM »
Thanks @naughty  :thumbs:
@kamikazi 100% agreed!I tried it with my AVR (situated elsewhere), and the attack and impact did improve.. however, I was using Airplay with Roon, so the overall SQ was Meh!  Thank you for the recommendation on those earpads  :2thumbs:   Will look into them.
@neilh I did (and perhaps still am) consider drop-shipping a Schiit Ragnarok 2, Lokius, and Freya +.However, I loose the benefit of warranty, etc. going that route.I am keeping an eye out for a 2nd Schiit Ragnarok 2 tho (get the other items when they ship to SA again)
Offline Wolvebain
« Reply #6 on: August 28, 2021, 11:38:15 PM »
Popped it into an old pelican case I used for my Sennheisers.. fits well and secure, despite the chunky headband
Offline Riaanee0
« Reply #7 on: August 29, 2021, 07:08:26 AM »
What eq are you using.
Offline Wolvebain
Offline Riaanee0
« Reply #9 on: August 29, 2021, 10:47:19 AM »
Thanks a lot iíve installed apo and my sundaraís are in a different class.It lack bass before eq  but not anymore.
Offline Wolvebain
« Reply #10 on: August 29, 2021, 03:56:07 PM »
Cool @Riaanee0  :thumbs:
Online naughty
« Reply #11 on: August 29, 2021, 08:26:43 PM »
for EQ try this site - the guy seems to be trying to get the sound quality to the Harman curve - i don't know who uses this site - but you need parametric EQ for most of the EQ settings - but for some he also gives 10 band graphic EQ settings as a bonus - he gave Graphic EQ settings for my HE4xx
https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets
Offline capetownwatches
« Reply #12 on: August 29, 2021, 08:55:53 PM »
I use the Oratory settings for my HD6xx and K701.
Transformative!
Offline Wolvebain
« Reply #13 on: September 01, 2021, 09:17:46 PM »
Quick update on the journey so far
I had to put the headband mod on hold ( Audeze ASY1096-KT and 1079-KT Replacement Headband/Yoke Kit ) as I am gearing up for another big purchase.
Resumed the burn-in process and am very impressed so far.  The bass really improved with the burn-in (with tweaking the headband, replacement earpads and using EQ). Improved punch, boom and rumble.
Offline Wolvebain
« Reply #14 on: September 11, 2021, 08:36:45 PM »
Whipped up a quick cable for it...
Cable 8x cores in total (4x core OCC + 4x core silver) with each core: 19 strands x 0.12mm.Each channel as 2x silver (V+) + 2x copper (V-) conductors.
Headphone connectors are Amphenol KS3PC-AU (these are the extended-shaft versions, as the jack is recessed on the HE6SE)And terminated with a Neutrik 4pin male XLR connector.
