Author Topic: Wanted: Laptop RAM (DDR2) Mahala...  (Read 1552 times)
Offline LAV
« on: May 23, 2011, 02:38:43 PM »
Yes, yes, I know, free lunches and all that. Trying to help a friend by repairing his sister's dead Sahara laptop. She's a nurse and still busy with her practical training. I suspect RAM failure, but I don't want to buy brand new RAM only to find the mobo's ill or the PC has some other scary affliction, so looking for a single 512 MB or 1 GB DDR2 laptop module. If it tests OK, then the machine could be worth fixing, otherwise not really worth it.
Vaal Triangle (Southern Gauteng)
Offline Juggy
Re: Wanted: Laptop RAM (DDR2) Mahala...
« Reply #1 on: May 23, 2011, 03:34:20 PM »
I'll take a look at home, I may have some.
Offline Juggy
« Reply #2 on: May 23, 2011, 08:03:07 PM »
How many slots does the laptop have?
I only have 2x256MB modules here. I am prepared to post them to you mahala if you want them.
Offline Skeeter
Re: Re: Wanted: Laptop RAM (DDR2) Mahala...
« Reply #3 on: May 23, 2011, 08:20:35 PM »
I have 1GB Samsung 533MHz 200-pin for you.
Sent using Tapatalk
Offline Juggy
« Reply #4 on: May 23, 2011, 08:27:47 PM »
Sent using Tapatalk
That would be a much better option.
Offline LAV
« Reply #5 on: May 23, 2011, 09:10:09 PM »
Thx guys, very kind. I'll obviously pay postage, and even send it back if needed and/or pay for it if I can get the old machine working. Just don't want to ask the owner to spend a lot if the machine cannot be saved, as she cannot afford it. Will PM further details.
