" My clients want to know what cable you used with my Switch?" asked pwatts. "Uhmm, a grey one'" said I, sheepishly. I have posted before how I prefer a generic CAT 6 cable with the earth on the plug removed and the cable grounded to system earth.
" There may be a theoretical benefit in using a very good cable between Switch and Streamer/DAC," said pwatts. The proto Switch has gone back to Pierre so it is Croak Switch and me only. I do have a sort of lower-middle-class Audioquest cable so I listened to that 'tween Switch and DAC.
Marvellous, fantastic, listen to all that detail, transients are ever so snappy, music sounds louder. That is on the stuff I listened to ad nauseam in the last month. Wading further out, unknown music sounded like it should have stayed unknown.
Then I switched back to the non-PEP-but-could-be grey cable. Unknown music now wanted to be explored, learned, unfamiliar spaces heard, journeys taken. Must be the earth then? I removed the earth from the solid Audioquest plug. Now the cable is dead. Oh well. R3000 moer toe.
To crown all that, I was fiddling with my telephone apparatus today and spotted Apple music. Something I subscribe to but never use. " Lossless", says the screen. It also says it is seeing JJ's Airport Express. So I dug up a piece of Toslink and wired (uhmm no, optic-ed?) that 'tween Airport express and DAC. 48/24. Blow me down, the same music but Apple does it nicer.
Damn, should have stuck to cassettes.
