Author Topic: Glue an old Philips bass driver dust cap  (Read 765 times)
Offline Zilch
  • Weet nie
  • Trade Count: (+26)
  • Total likes: 156
  • ... never finishing projects
« on: July 14, 2021, 10:59:27 AM »
So I recently got a very old pair of Philips speakers.  Philips RH496, from the late 60s.  Older than my dad :BWAHAHAH:
Anyway, upon close inspection, I discovered the dust cap had fallen off one of the bass drivers.  FEAR NOT!  I have many friends :giggle:
Thankfully, Dewald Visser knew what to do!  So I gave him a phone call, asking how I have to repair the driver.
Dewald recommended I use contact glue, and masking tape to hold the cap in place.  He explained the reason you want to use contact glue is in case you ever have to replace the surrounds or do something to the driver.  If you have to align the former when applying a new surround, it's useful to be able to access that little 'hatch'.  So to access it you use some alcohol to soften the contact glue, and then you can remove it.
Naturally, I never followed the latter part of the aforementioned instructions, as I never felt the need to replace the surrounds.
Before applying the glue, I'd recommend wiping the cone with a dry microfibre cloth, as I did.  It gets rid of unwanted dust and old debris.
You'll also want to align the dust cap in its original position.  This is to close any gaps and have it seal properly.
Anyway, I went on my merry way to applying the glue.  Dewald says to apply it directly to the rear of the dust cap only, straight from the nozzle.  He also says that you would rather have more glue, then too little.
Then what I did with the masking tape was (I think) pretty clever.  I spun it around my finger, with the glue side facing outwards.  Then stuck it against the dust cap.  Afterwards, I used another piece of masking tape so that when I hold it with my fingers, it doesn't stick to my fingers.
After I finished the job, I left everything as is for 24 hours.  Do not remove the masking tape, just leave it.  Only thing I did was put a bag of coins on the dust cap to have the glue make a better, tighter seal.
I think the end result is pretty impressive...
« Last Edit: July 14, 2021, 11:11:29 AM by Zilch »
If you don't understand the difference between "their", " there" and "they're" then your a idiot.
Offline Zilch
  • Weet nie
  • Total likes: 156
Re: Glue an old Philips bass driver dust cap
« Reply #1 on: July 14, 2021, 11:00:17 AM »
Offline Zilch
  • Weet nie
  • Total likes: 156
« Reply #2 on: July 14, 2021, 11:14:50 AM »
The dust cap itself is made from a composite material.  It's about 2-3mm thick, and 40mm dia.  It's also about as heavy as Aluminium. So I knew it had to be glued on, otherwise it would've changed the T/S parameters and made the FS much higher, resulting in worse bass performance in one loudspeaker.
Offline Zilch
  • Weet nie
  • Total likes: 156
« Reply #3 on: July 14, 2021, 11:18:04 AM »
Dankie @ghostinthemachine vir al jou hulp!  What would I do without you :groovy:
Offline ghostinthemachine
« Reply #4 on: July 14, 2021, 06:22:25 PM »
Its only a pleasure! :-)
Hi-Fi is what YOU make of it. See my Facebook page: https://www.facebook.com/dewaudioza & my YouTube Channel: https://www.youtube.com/channel/UC1YZJWgrGwdCYSyGP8JEd7Q
Offline DeonC
« Reply #5 on: July 15, 2021, 08:24:37 AM »
Very nice work! Well done. :clap:
Life is not measured by the breaths you take, but by the moments that take your breath away.
