Author Topic: Affordable Valve integrated - MUZISHARE X7 KT88  (Read 546 times)
Offline Nidri
Re: Affordable Valve integrated - MUZISHARE X7 KT88
« Reply #1 on: June 06, 2021, 09:34:36 AM »
Seems fairly similar to Cayin (not a bad thing).
https://www.youtube.com/watch?v=FIl3BtdonRI
I've also read that Muzishare is made in the same factory as Line Magnetic, but I can't confirm that to be true.
Whilst Nidri takes reasonable care to ensure that the information in this message is correct and up to date, this might not always be the case. Nidri does not give any warranties as to the accuracy and safety of any information appearing in this message.
Offline kamikazi
« Reply #2 on: June 06, 2021, 05:16:15 PM »
Muzishare seems to be a new kid on the block offering good performance products, there are quite a couple of impression up on Youtube. I've been checking out a couple of value amplifiers from that side of the world and they seem to be pretty good for the money, the other being Willsenton.
Unfortunately it is always the shipping costs that trip them up to these part of the world (the transformers are heavy). So packaging and shipping is also a bit of the worry and if these arrive damaged then you are going to have trouble with support.
Offline Qualityten
« Reply #3 on: June 16, 2021, 02:12:09 PM »
I wouldn't look twice at those Chinese-made amps while amps like the Mars Companion are available locally, with proper local manufacturing and support.   http://www.marsamps.co.za/product/mars-companion/
