Author Topic: Valve Rectifier Database, Substitution Guide, Notes and Companion Files  (Read 668 times)
Offline marantz123
  • Forum Moderator
  • Total likes: 166
  • I learnt more from The Internet when it was slower
Fellows
Kudos to the team behind the collection and documentation of this information and making it available at a single location. The notes below the database are valuable and very informing. Also included are the associated "companion" files. Enjoy !  :)
Valve Rectifier Database, Substitution Guide and Notes:
http://www.fourwater.com/files/fullrect.txt
Companion Files:
Vacuum Tube and Related Information (excellent!):
http://www.fourwater.com/tubeinfo.htm
Rectifier Notes:
http://www.fourwater.com/files/rectnotes.txt
Gas Rectifier Notes:
http://www.fourwater.com/files/gasrect.txt
Voltage Regulator Tubes:
http://www.fourwater.com/files/voltreg.txt
Marantz123.  :)
« Last Edit: June 05, 2021, 12:08:41 PM by marantz123 »
Online Family_Dog
Yes :)
Offline charles
Interesting sites.
Just be careful as some of the substitution notes are not correct.
Offline Heinwil1
Re: Valve Rectifier Database, Substitution Guide, Notes and Companion Files
« Reply #3 on: September 15, 2021, 10:26:55 AM »
Morning All,
I have a box of valves but most of them are not marked. How can i find out what valve type and values they are.
Regards
Online Family_Dog
« Reply #4 on: September 15, 2021, 12:41:34 PM »
Try plonking them in the fridge or freezer and then see if you can see any faded markings when you breathe on them.
If not, you will have a problem.
