Author Topic: Projector mount for a sloped ceiling?  (Read 1588 times)
Offline flacster
« on: November 18, 2020, 05:28:26 PM »
I'm buying an Epson EH-TW650 soon and want to mount it on the ceiling. The room is high at the end where I want to project the image, but then slopes down at about 30 degrees from about 2m. So the projector mount needs to be strong and stable even at an angle.
A quick search picked up this ceiling / wall mount bracket on an overseas AV forum: https://www.amazon.co.uk/SIMBR-Universal-Projector-Extension-Capacity/dp/B06XBV6QDM/ref=pd_lpo_vtph_23_tr_t_2?_encoding=UTF8&psc=1&refRID=ZMWJMZ4GFZJ0DF8TCDDR
Is there a good provider for this kind of thing locally?
Offline resham
Re: Projector mount for a sloped ceiling?
« Reply #1 on: November 20, 2020, 08:22:31 AM »
Hi there
I have PM'ed you
R
Offline georgev
« Reply #2 on: January 30, 2021, 05:46:00 PM »
Hein from Sound Structures will custom make these mounts.
They are solid and made to fit the projector.
" For by Grace you have been saved through Faith..............It is the free gift of God". Ephesians 2: 8-9
