Author Topic: Transistors wanted - Toshiba & Matsushita  (Read 205 times)
Offline ghostinthemachine
« on: November 12, 2020, 10:08:38 AM »
Good day friends
I am in need of the following transistors:
2SA913 (Matsushita)
2SC1913 (Matsushita)
2SA912  (Matsushita)
2SC1885 (Matsushita)
2SC2565 (toshiba)
2SA1095 (toshiba)
Thanks in advance
Conquer yourself rather than the world - Rene Descartes
Offline marantz123
  • Forum Moderator
  • Total likes: 139
  • I learnt more from The Internet when it was slower
Re: Transistors wanted - Toshiba & Matsushita
« Reply #1 on: January 21, 2021, 08:31:33 PM »
For 2SA913 : MJE15033 is possible and locally available. 2SA1859 is said to be a closer match and is available at Digikey.
For 2SC1913 : MJE15032 is possible and locally available. 2SC4883 is said to be a closer match and available at Digikey.
The MJE should work well enough. The Ft (transition frequency) is a minimum rating on the spec sheet at 30MHz. The typical value should be close enough (to not cause a problem) to the typical rating of the 2SC part which is 120MHz.
Your originals should be classed in one of these gain groups P (65-110), Q (90-155), R (130-220), S (185-330). Would be interesting to know which one you have.
Will take a look at the other transistors, shouldnt be an issue finding suitable subs if the originals are unavailable.
« Last Edit: January 21, 2021, 08:37:09 PM by marantz123 »
