Author Topic: Channel level on AVR after adding a power amplifier.  (Read 610 times)
Offline Burzat
« on: October 03, 2020, 04:30:22 PM »
After adding a power amplifier to the pre outs of the AVR. The power amp gains are set to half. What should the channel level be on the AVR be? The channel level goes from - 12 to +12. Default is 0.
Offline TimbaLand
Re: Channel level on AVR after adding a power amplifier.
« Reply #1 on: October 03, 2020, 04:54:00 PM »
I would put the power amp gay on on max and run act auto set up to claim rate the levels
HT: Marantz AV7705|RMB1585|RMB156|RB956 Optoma UHD40| Nvidia Shield
Stereo: Mark Levinson No 380s, 335| Cary Audio 200 TS| Bluesound Node
Speakers: B&W 802 Diamond, HTM2 Diamond|  B&W ASW850 and Velodyne DD15 Subwoofers | 685 and DS3 surround |4x CCM
Offline scrarfussi
« Reply #2 on: October 03, 2020, 07:21:20 PM »
What power amp is it with gains ?
suum cuique pulchrum est
"Then Said my heart here will i take my rest."
Offline Burzat
« Reply #3 on: October 03, 2020, 08:08:44 PM »
Rotel. Each channel has a knob to increase or decrease the output
Offline TimbaLand
« Reply #4 on: October 03, 2020, 10:05:09 PM »
My phone screen is broken and it makes so many typos. I have the same Rotel which I use for my Atmos speakers. I put the dials halfway and let the processor do the level matching.
Offline Andile
« Reply #5 on: October 03, 2020, 10:15:39 PM »
That's new!!
How do you put a power amp GAY :thinking:
Marantz SR7013 | Denon DVD2500BT | Yamaha NS-F700 | Audioquest Forest HDMI | Atlas Hyper 3.5 Speaker Cables
Offline TimbaLand
« Reply #6 on: October 04, 2020, 08:45:06 AM »
That's new!!
🤣🤣🤣🤣. My phone screen is broken. Half the screen is dead and some alphabets donít respond resulting in bad grammar 🙈
Offline Genesis777
« Reply #7 on: October 04, 2020, 09:08:44 AM »
It all depends on your speakers and your room acoustics. I have set mine on around plus 5 for my fronts using the power amp but I expect that leaving them on zero would also work depending on the levels of your other speakers. Calibrating with Audyssey will also give you a good idea where these should be set.
« Last Edit: October 04, 2020, 09:16:12 AM by Genesis777 »
Denon RX-A3600H, Parasound 2250 v2, Optoma UHD51, B&W 683 S2, B&W HTM61 S2, B&W 685 S2, Yamaha YST-SW800, Cambridge Audio 640C, Sony Blu-Ray BDP-S7200
Offline Burzat
« Reply #8 on: October 04, 2020, 10:19:04 AM »
Ok. Recalibrated. did a couple manual adjustments as well. Here is where its at on the receiver :
Fronts (Power amp) = -4
Centre = +6
Rear = -2
Sub = +5
Sounds good to me.
Thanks for all the advice.
PS. Just a side note on the the power amp. When I bought it. It was sold to me as "straight". If I knew it was "Gay" then no ways i would have bought it. If it has intentions of coming out the closet then thats bad news. I wont tolerate it ............. :ROFLMAO:
Offline TimbaLand
« Reply #9 on: October 05, 2020, 09:00:16 AM »
Some sellers donít always make a full disclosure about the status of what they are selling. No need to worry though because gay ones tend to have more character 🤣🤣🤣
Offline jlaubza
« Reply #10 on: October 07, 2020, 05:05:13 PM »
Nothing wrong with a gay amp especially if it is loud and proud.
