Author Topic: Simple adjustable PSU for NIXIE tubes  (Read 667 times)
Offline Mars
  • Total likes: 73
    • Mars Tube Audio
« on: November 19, 2019, 06:01:12 PM »
Hi All
I am building an adjustable PSU for IN-6 tubes so the light brightness can be adjusted. Can anyone check this design and correct me if I got something wrong?
Power requirements:
Working voltage: 150V-170V;
Working current: 2.5 mA.
I design for 10 tubes, thus 25mA
This is what I propose. I think I'll heatsink the TIP50 for safety.
Will it work?
OEM manufacture of Tube Audio
Phono Pre-amplifiers
DIY Kits
DIY Workshops
Offline Den123
Re: Simple adjustable PSU for NIXIE tubes
« Reply #1 on: November 19, 2019, 06:43:46 PM »
You are going to have nearly 240V DC on the collector, so it will”bless you” right out of your socks if you touch it!
Offline Mars
  • Total likes: 73
    • Mars Tube Audio
« Reply #2 on: November 20, 2019, 10:25:29 AM »
You are right! I will probably add some resistors in series to drop die DC to 160V.
DIY Kits
DIY Workshops
Offline Nchebe
« Reply #3 on: November 20, 2019, 12:12:26 PM »
Yup! Also, the resistor divider (250k-10k) won't divide the voltage when wiper is right at the 'top' of the pot, thus putting the full DC voltage on the output.  A 100k resistor between + and 'top' of pot should limit you to around 160V, else get a transformer with a 115V secondary rating to limit output voltage (VDC=1.4 X VAC)
Offline Mars
  • Total likes: 73
    • Mars Tube Audio
« Reply #4 on: November 20, 2019, 05:13:40 PM »
I decided to keep the design simple.
The results were good. Only 1W dissipation (at idle) on the 10K wirewound pot and an adjustable 154V to 75V on the output.
Hopefully this will do the job.
DIY Kits
DIY Workshops
Offline fredeb
« Reply #5 on: November 20, 2019, 06:55:35 PM »
Interesting watching you develop your adjustable circuit Karel . I'm busy playing around with different resistor values on the PSU for my phonostage to see the difference at different operating points , this adjustable circuit would've been handy to quickly find the right operating point . :)
Jan Smuts
Offline Den123
« Reply #6 on: November 21, 2019, 06:19:55 PM »
Ag. I am an idiot! I forgot. Karl, look at the LR8 chip from Microchip. Linear voltage regulator. 1.2 - 438V. TO92 package, so low power. Built in current and temperature regulation. Really nice find. Not expensive either.
Offline handsome
« Reply #7 on: November 21, 2019, 09:46:31 PM »
LR8 doesnt do a lot of current. nixie tubes are display tubes they dont need a super accurate or clean supply so something basic like karel has done is cheap n easy
