Author Topic: Asus Mobo Red DRAM LED problem  (Read 942 times)
Offline chrisflex
  • Trade Count: (+40)
  • Total likes: 140
  • I know it's only rock 'n' roll but I like it...
« on: September 22, 2019, 03:38:09 PM »
The Red DRAM LED stays on
No display
Machine just won’t boot up.
Tried different RAM
Tested the RAM in another PC it checks ok.
Any advice welcome.
"...songs about dreams...Actually, songs that are dreams for me.
They seem to go beyond songs about something, they seem to go someplace
where thay are like dreams themselves when you hear them."
Tom Waits
  • Trade Count: (+150)
  • Total likes: 682
  • Cape Town Hi-Fi Club - we're getting better sound
Re: Asus Mobo Red DRAM LED problem
« Reply #1 on: September 22, 2019, 05:05:59 PM »
You don't say how old it is
Try:  Different power supply
        Remove and replace the CPU
        Unplug everything (HDD, optical drive, USB connectors, extra fans) except the mobo power plugs
Is it clean (free from dust)?    I fixed a 8 year old PC last week by removing the memory and CPU and going over it and the PSU and board with an industrial blower.  Clouds came out for several seconds.   It came back to life after that.  Of course that might have just been luck
Offline chrisflex
  • Total likes: 140
« Reply #2 on: September 22, 2019, 05:30:03 PM »
Thanks Chris
Temporarily removed the CPU then booted up, that brought up the BIOS menu
In the BIOS reset to the optimized defaults
All ok now.
Tom Waits
Offline Babbalas
« Reply #3 on: November 04, 2019, 10:43:06 AM »
Had the same issue a couple of months ago, believe the issue was the CPU wasn't seated properly after moving the PC.
