Author Topic: TEAC A-3340 does not want to play or record  (Read 5874 times)
Offline Mars
  • Total likes: 92
    • Mars Tube Audio
« on: August 26, 2019, 10:18:21 AM »
Hi All
I have this reel-to-reel that seems to be in good condition, except the play/record function does not engage.
Has anyone got experience with this model?
Before I dug deeper I took some photos.
Back panel removed:
OEM manufacture of Tube Audio
Phono Pre-amplifiers
DIY Kits
DIY Workshops
Offline exodec
Re: TEAC A-3340 does not want to play or record
« Reply #1 on: August 26, 2019, 10:20:52 AM »
This is a A-3440 model. Very nice 4 tracks deck!
从我的 iPhone 发送,使用 Tapatalk
Full Class A as a Naturally Aspritaed! Vinyl and Tube are always the Best!
Offline marcochezzi
« Reply #2 on: September 04, 2019, 03:26:17 AM »
Look I’m working on a wild assumption here as I have never personally seen or worked on one of these, but if that round silvery thing below the black transformer is the capstan motor, there should be a belt between that and the capstan slightly below and to the left of the “assumed” motor..??
The capstan is the circular item which you only see the top half of, just above the control signal socket on the back panel, greyish color with a couple of large holes machined in it..
If that is broken or missing maybe the lack of drive is your issue here..
« Last Edit: September 04, 2019, 03:42:27 AM by marcochezzi »
Offline marcochezzi
« Reply #3 on: September 04, 2019, 03:35:20 AM »
Yep, your belt is missing, just looked at a tear down video for that machine and you need a belt exactly as I mention above, no belt, no function..
See below image, you can clearly see the belt..
« Last Edit: September 04, 2019, 03:37:53 AM by marcochezzi »
Offline Mars
  • Total likes: 92
    • Mars Tube Audio
« Reply #4 on: September 04, 2019, 02:08:56 PM »
Well spotted Marco! Let me follow up and report back.
DIY Kits
DIY Workshops
Offline Den123
« Reply #5 on: September 05, 2019, 05:10:59 PM »
I think I have one of these sets in storage.
