Author Topic: Best router for 1gbps internet.  (Read 19763 times)
Offline Frank007301
« on: July 24, 2019, 10:03:21 AM »
Hi all
I was wondering what the best router would be for a 1gbps internet line. I currently have 2x Apple Airport Extreme's. They work well but i am wondering if i can do better. I have used an Asus AC87U before and liked it a lot but i was using that as the router and then the AirPorts for the wifi. I did not like this setup and just used the AirPorts.
B&W CM9's, CMC2, 4x  686's|2x M&K M4T Atmos|Marantz SR6011|Oppo UDP 203|Rotel RB1080|2xSVS PB1000|Optoma HD26 projector|120" Grandview screen|Apple TV4|Roku 4
Offline tab.deboer
« Reply #1 on: July 24, 2019, 09:42:00 PM »
Depends on how much you want to spend.
I'd suggest looking at Ubiquiti, especially their enterprise range, Unifi. Pair it with a "USG" (Unifi Security Gateway) for routing and firewalling. And potentially a Unifi PoE switch, and of course some dual band AP's. I recommende the AC Lite or LR.
Otherwise something like the Ubiquiti Amplifi series. Add Mesh nodes as you encounter deadspots.
amplifi.com
Offline MeTsU
Re: Best router for 1gbps internet.
« Reply #2 on: July 24, 2019, 11:05:47 PM »
I really like Ubiquiti's products.  Our setup at home (for reference on coverage - an old, thick walled, single story, 400m2 house) is:
* USG - Handles the routing & firewalling
* US-8-60W - An 8 port switch with 4 ports that offer POE
* UAP-AC-Lite - 3 of these units provide full coverage at home.
I'm hosting my Unifi Controller in a Google Cloud environment.
Cost wise, I can't recall exactly, but somewhere in the region of R6500.
We are unfortunately limited to 100Mb fibre (lucky you for having 1Gb), but this setup has served us well in all of our streaming and other needs.
Offline Dolby
« Reply #3 on: July 26, 2019, 10:36:17 PM »
I read the question as router (ie before WiFi)?
If so, anything with a dedicated 1Gbit dedicated WAN. Maybe the Zyxel VMG3625?
Otherwise, the others answered ...  a mesh is a decent solution :) The standard reply is Ubiquity but there's a product called AirTies which is as good or better.  Unfortunately, it doesn't have the brand name so no one looks at it
« Last Edit: July 26, 2019, 10:39:43 PM by Dolby »
Offline MeTsU
« Reply #4 on: July 27, 2019, 12:42:57 AM »
The Ubiquiti USG is a router.
Before I got the USG, we had a TP Link Archer D7.  As long as your choice of router has a WAN/EWAN port and the switch component of the unit is 1Gb, you're sorted.
I personally am not too fond of the Zyxel units - to each his own though.
Offline Juggy
« Reply #5 on: July 27, 2019, 07:58:13 AM »
Just remember that if you go for the USG and want IPS enabled along with a 1gbps connection you'll need one of the beefier models
Warning: Enabling IDS/IPS will affect the device maximum throughput. USG: 85 Mbps, USG-Pro: 250 Mbps, USG-XG-8: 1 Gbps.
Offline Dolby
« Reply #6 on: July 27, 2019, 04:22:17 PM »
Yea I recommended because of cost - I think it alone is half the price of the USG, let alone any of the other ad ons. It also works for most people, but your route may be best if you have a larger house and your budget multiples bigger :)
Offline scrarfussi
« Reply #7 on: July 29, 2019, 08:17:24 PM »
Mikrotik For me  I prefer them to the Ubiquiti  Products
suum cuique pulchrum est
"Then Said my heart here will i take my rest."
Offline Frank007301
« Reply #8 on: August 06, 2019, 12:36:07 PM »
Hi
Thank you for all the advice. After some testing i am happy with the Apple Airport Extremes. I think i am going to wait for 802.11AX or WiFi 6. Asus have some routers out at the moment but they are about R8-10k.
I am seriously looking at the Ubiquiti stuff though. Will wait for the WiFi 6 stuff though. Will upgrade to a 10gbps network at the same time.
« Last Edit: August 06, 2019, 12:42:13 PM by Frank007301 »
Offline Frank007301
« Reply #9 on: August 06, 2019, 12:40:45 PM »
Offline GoodEnoughGear
« Reply #10 on: August 06, 2019, 02:34:05 PM »
Sweet mercy!
Mobile: LG V30, CA Andromeda
Portable: LH Labs GO2A SE, KEF M500
Home: Soekris DAC1541, Genelec 8030+7050, Eddie Current Black Widow II, HD600
Offline Juggy
« Reply #11 on: August 07, 2019, 07:42:33 AM »
Cheese and crackers that is a fast connection. You building a datacenter in your garage?
Offline WGS
« Reply #12 on: August 07, 2019, 09:14:23 AM »
That could be the 1gig lite package that many providers are doing, been out for a while now but with restrictions
if i recall correctly, 1gbs is for local sites, international is limited to 100/100....but it could have changed now
Offline Frank007301
« Reply #13 on: August 07, 2019, 09:47:52 AM »
I dont know about the 1gbps lite package. It might be limited but not to 100/100.
Offline WGS
« Reply #14 on: August 07, 2019, 09:57:28 AM »
Thats awesome speeds... :2thumbs:
The 1gbps lite package from Cool Ideas below
https://shop.vumatel.co.za/package/4kBywL6wU
