Author Topic: HDMI on front panel flashing Yamaha 3020  (Read 339 times)
Offline The Don
« on: May 13, 2019, 05:55:14 PM »
Hi Guys
I am new to the forum, recently I found out that my HDMI out from my Yamaha RX 3020 has stopped working. The red hdmi light on the front panel flashes and no signal is on the TV, the system worked well until I had a storm my Decoder went and i suspect it blew the two ports. I tried different devices and change the cables on the ports by they don't seem to work.
Is it possible that only the two ports got damaged.
Offline RS4
Re: HDMI on front panel flashing Yamaha 3020
« Reply #1 on: May 13, 2019, 06:07:01 PM »
Itís common for only the outputs to get damaged. It could also be the TV thatís damaged.
I can fix it for you should it be the amp, pm me if interested.
Optoma
Cyrus, Dynaudio, Anthem, JL Audio!
 :oppo: ?
Offline The Don
« Reply #2 on: May 15, 2019, 02:36:28 PM »
TV is working fine.
 i will PM you.
