Author Topic: DS Audio Stylus Cleaner from Japan, easy, safe and effective  (Read 1749 times)
Offline Hi-Phibian
  • Trade Count: (+44)
  • Total likes: 120
    • Croak Audio Exploration
The DS Audio ST-50Stylus Cleaner brought to you by Croak Audio Exploration.
Three years after launching the world's first optical cartridge DS Audio has created a stylus cleaner - not just for optical cartridges but also the far more conventional moving magnet and moving coil types.
The ST-50 comprises a cleaning pad made from a urethrane resin of the type specifically developed for ‘cleanrooms’ - microparticle-free rooms used in industries as varied as pharmaceutical and medical to food and electronics, and from which the inspiration for the ST-50 was drawn. It works to remove dust from the stylus tip by absorbing microscopic dust particles from it.
The ST-50, which has a nickel-plated casing with a leather underside, is designed to sit on the turntable platter (unlike other bulky polymer cleaners) while the user gently lowers the tonearm (two to three times per clean) to touch the stylus onto the gel pad, taking care not to rotate the platter during the process.
While typical stylus cleaners use brushes and solvents, DS Audio ST-50’s method is ‘extremely gentle and safe’. it is long lasting too, as the urethrane gel pad can be washed (rinsed it tap water, dried at room temperature) and re-used.
Our stocks are on their way and introductory price will be R999.00
Secure yours now.
Proprietor of Croak Audio Exploration.
Fair, not crazy, cash paid for turntables and tonearms from Rega, Linn and Thorens.          http://www.croak.co.za
Offline Hi-Phibian
  • Total likes: 120
Re: DS Audio Stylus Cleaner from Japan, easy, safe and effective
« Reply #1 on: July 13, 2018, 07:21:58 PM »
Right. Stocks are here earlier than expected.  Woohoo.
[Anyone who thinks that wealth is measured in money is blind and narrow minded.  Wealth is obviously measured in turntables and records.]
Offline Hi-Phibian
  • Total likes: 120
« Reply #2 on: July 17, 2018, 05:13:30 PM »
These are selling well and positive reports coming in.  Even a repeat order from an early adaptor for his 2nd table
Offline Hi-Phibian
  • Total likes: 120
« Reply #3 on: October 17, 2018, 12:51:38 PM »
Nice review on AVSA.
http://bit.ly/AV_ST50rev
Offline crasher
« Reply #4 on: October 17, 2018, 01:24:27 PM »
So happy with mine works like a charm quick easy and gives me piece of mind I am not bending or damaging anything.
Offline Michon
« Reply #5 on: November 18, 2018, 07:27:07 PM »
Do you have stock at the moment? If so please keep one for me. I will be able to collect this coming week.
Plate, vakuum buis versterkers en breëband oorvormers.
Offline Hi-Phibian
  • Total likes: 120
« Reply #6 on: November 18, 2018, 11:11:32 PM »
New batch leaving Japan via courier this week.
Offline dragonmts
« Reply #7 on: November 19, 2018, 06:50:52 AM »
Same price?
If music be the food of life, play on!
Offline Hi-Phibian
  • Total likes: 120
« Reply #8 on: November 19, 2018, 07:20:23 AM »
I will do my best.   If I can’t make it work
Once properly costed it may be R1099
Offline Michon
« Reply #9 on: November 19, 2018, 12:37:27 PM »
Thank you. Put me down for one when they arrive please.
Offline Hi-Phibian
  • Total likes: 120
« Reply #10 on: November 20, 2018, 09:26:53 AM »
Hello
New stocks expected by Wednesday next week.  The 28th of November.
Offline Michon
« Reply #11 on: November 21, 2018, 06:07:00 AM »
Hello
This is good news. My stylus could not wait much longer than that.
Offline Michon
« Reply #12 on: January 07, 2019, 06:58:05 PM »
Thus far I have had good results with this product. I haven't needed to wash it yet as I still have dust free surface area on the cleaning pad. I am curious about how the washing will go and whether it will return to its original efficacy after a wash. Thank you for making this product available. I am satisfied with this purchase.
« Last Edit: January 07, 2019, 07:05:40 PM by Michon »
Offline Hi-Phibian
  • Total likes: 120
« Reply #13 on: January 07, 2019, 07:06:18 PM »
It’s a great product.
I have washed mine half a dozen times already and it still works exactly the same
The reason for the “many”
washes is just that I like it to be near spotless when I show it to folks.
Wash with confidence I would say.
Offline Michon
« Reply #14 on: January 07, 2019, 07:17:34 PM »
Baie dankie.
