Author Topic: Different ceiling acoustic effect - I need advice  (Read 1284 times)
Offline bearenzo
« on: March 22, 2018, 01:32:53 PM »
I have an opportunity to re-do my music room ceiling, am wondering should I go to vaulted ceiling like this
https://www.doityourself.com/stry/constructing-a-vaulted-ceiling
Or open trusses ceiling like this http://www.favething.com/m-hardwicke/cool-s-t-for-home-office/roof-trusses/
Does anyone has a music room with the above mentioned ceiling? Any problem with it?
Or should I just stay with the normal flat ceiling?
Offline Rodney_gold
Re: Different ceiling acoustic effect - I need advice
« Reply #1 on: March 22, 2018, 06:17:12 PM »
Aesthetically , I like the trusses more vaulted looks like a church
You will be increasing the volume quite dramatically and the sound has further to travel so reflections off the flat ceiling are attenuated , giving the sense of openess..
Only real issue is predicting room modes , difficult with a pitched ceiling
I dearly wish I could gain a meter + on my 2.5m ceiling..but the slab says no...I even considered excavating my room a meter..too much of an undertaking
Roon/tidal > Squeezebox touch> Trinnov St2 >2x Devialet D premiers>  Vivid audio Giya G1 spirits ..fully treated room
Offline Jukkelstukkel
« Reply #2 on: March 23, 2018, 01:33:26 PM »
My experience with trusses 'in' open ceiling is that it causes acoustic anomalies which is no good for imaging and accuracy. Normal ceiling preferred with double layer rhino board.
Offline bearenzo
« Reply #3 on: March 23, 2018, 03:25:55 PM »
Perfect for "Gregorian chant"    :giggle:
Offline bearenzo
« Reply #4 on: March 23, 2018, 03:31:37 PM »
Noted and thanks, that's what I'm worry about.
But how about this shape ? ( picture at the bottom right) http://i1.wp.com/therusticwillow.com/wp-content/uploads/2015/11/vaulted-ceilings-pin.jpg
Offline John.Perry
« Reply #5 on: June 14, 2018, 08:47:20 AM »
Do you want to install any room treatment panels to absorb, diffuse or trap?
  • Trade Count: (+126)
  • Total likes: 208
  • Cape Town Hi-Fi Club - get better sound
« Reply #6 on: June 14, 2018, 09:00:34 AM »
One of the hifi club members (fellow on the right) has a vaulted ceiling in his large living room.   The sound is superb, but being a 15m x 5m room with the ceiling 5m up, you have to turn it up a bit
The tiles against the ceiling are very soft in texture
Even duct tape can’t fix stupid… but it can muffle the sound
Offline bearenzo
« Reply #7 on: June 15, 2018, 01:08:49 PM »
Not planning to do room treatment at the beginning, might add some if the sound isn't good.
Offline bearenzo
« Reply #8 on: June 15, 2018, 01:11:42 PM »
Wow, that is a 375 cubic meter huge space, he probably has a powerful amp or very high efficient speakers.
