Author Topic: crossover design  (Read 2725 times)
Offline KKAN
crossover design
« on: September 20, 2017, 04:31:50 PM »
Hey guys
How do I design a cross over with limited available specs for the drivers? I have acquired drivers that came off the mission m6ci center and plan on building 2 little
 2way bookshelf's
Re: crossover design
« Reply #1 on: September 20, 2017, 05:09:11 PM »
I am not sure what you are going to do as far as box design is concerned without the speaker parameters.
This site is quite helpful for XO design. https://www.diyaudioandvideo.com/Tutorial/DesignBuildCrossover/
I see the frequency response is 65 - 20,000Hz, but that will include the tweeter.
http://www.superfi.co.uk/p-7109-discontinued-mission-m6ci-centre-speaker-black.aspx
https://www.hifix.co.uk/mission-m6ci-centre-speaker
Frequency Response at 3dB 65Hz to 20kHz
Sensitivity SPL/m/2.83V 87dB
Amplifier Power Range 25 to 100 watts
Dimensions (HxWxD) in mm 178x480x251
Cross Over Frequency 2.4kHz
Effective Volume 8.7 litres
In room frequency bandwidth -6dB at 60Hz to 28kHz
Enclosure Type 2 way reflex loaded
Nominal Impedance 8 ohm (minimum3.8 ohms)
« Last Edit: September 20, 2017, 05:15:55 PM by Curlycat »
“I have realized that the past and future are real illusions, that they exist in the present, which is what there is and all there is.”  Alan Watts
Offline KKAN
« Reply #2 on: September 20, 2017, 08:55:55 PM »
Hey curlycat thanks, yep that's about what I found as well, very new to diy, so trying to figure what I can do with this information.
Also not exactly sure what to do with the box :-\
Offline bbe22
« Reply #3 on: September 20, 2017, 09:24:35 PM »
http://techtalk.parts-express.com/forum/tech-talk-forum/38661-the-speaker-building-bible       be patient a lot of info here
the easier  but correct way out would be to find a forum member that can measure and design a proper X-over and box for those drivers, and where you will be using them,  and then you build it out   :)
Offline KKAN
« Reply #4 on: September 21, 2017, 08:22:30 AM »
 :thumbs:
I'm in PMB, so if anyone is in KZN with the know how regarding this i'd like to visit  :cleansound: :dop:
Els im just going to wing it ;D
« Last Edit: September 21, 2017, 08:24:58 AM by KKAN »
