Author Topic: Ceiling Speakers ( Light bulb Sized)  (Read 2208 times)
Offline StewartAylett
« on: February 02, 2017, 10:35:10 AM »
Has Anyone Got these type of Speakers Installed
Wanting them for the Bathrooms so they don't need to be loud Just sound good
Just wondering If anyone had any experience ? or had any installed in their homes
Offline naughty
Re: Ceiling Speakers ( Light bulb Sized)
« Reply #1 on: February 02, 2017, 10:58:44 AM »
Those Cambridge Audio speakers pictured use BMW drivers .... you should read up on those to see if you will like their sonic signature ..... some forum members don't
Also since you want to use in the bathroom is would rather look at speakers designed for marine/boat usage since bathrooms can get steamy so IMHO you need speakers with a degree of moisture resistance
« Reply #2 on: February 02, 2017, 11:04:27 AM »
Had A look at These from Kef safe for Bathrooms
The Ci50 Is the Same size as my downlights and The Rest of my house I Run Kef so why change
or the ci80
Offline naughty
« Reply #3 on: February 07, 2017, 02:49:22 PM »
sorry not BMW drivers .... (bloody auto-correct on the cellphone) its actually BMR (Balanced Mode Radiators)
those Kef ones may suit your requirements as long as they have a measure of moisture resistance  :thumbs:
« Reply #4 on: February 13, 2017, 09:38:18 AM »
Have Checked They All Good For Bathroom Use
However I Have seen these Speakers and Wondering If Anyone Has any Knowledge / experience with them 1 speaker outputting stereo
Online Ju_dy@RT
« Reply #5 on: March 08, 2017, 02:09:33 PM »
We sell the Monitor Audio ones...
I think LeonJHB still has some installed.  PM him he will give you an honest review.
Offline Ravo
« Reply #6 on: April 07, 2017, 07:26:30 AM »
Been researching the bathroom speaker options recently, and although it does not need to be loud, it still needs to overcome the noise from the shower.  Purchased the POLK RC60i last week and extremely impressed with them. Read close to 80 reviews on them as well.
Offline Reng
« Reply #7 on: April 12, 2017, 06:09:43 PM »
If you replace the lights you will have Music but shower in the dark - does not make sense :sh1tstirrer:
Offline naughty
« Reply #8 on: April 12, 2017, 07:04:13 PM »
I dont think he wants to replace the lights - you can keep the lights but most people will be able to comparatively easily make holes in the correct size for spot lights or downlighters (usually around 80mm) far easier than for example to make holes for 8" or larger speaker drivers
