Author Topic: Home Lan with Switch Issue  (Read 5833 times)
Offline sudyP
« on: October 15, 2016, 10:39:19 AM »
Hi Everyone
Was hoping someone can help me with an issue I'm experiencing. I am unable to connect my PC to my home network but things like my TV and xbox connect fine. My setup is essentially like this:
PC, Xbox, TV <---> Unmanaged Switch <---> Managed Switch <---> Router
I'm stumped, as tried plugging another PC in as well and it doesn't work http://www.avforums.co.za/Smileys/default/sAng_banghead2.gif
Offline LocknLoad
  • Chasing the midbass slam
Re: Home Lan with Switch Issue
« Reply #1 on: October 15, 2016, 11:41:11 AM »
Are you saying the PC does not connect to either the unmanaged and managed switch or only the managed switch?
Things to check...
1 - No VLANs configured on the managed switch
2 - No static IP or DNS configured on the PC
3 - DHCP scope on the router is setup correctly
I assume you have tried your PC using the port and cable of the Xbox or TV?
Fan/Owner of KEF/Yamaha/Pioneer/Rotel/Paradigm/Emotiva/Dayton/TC Sounds/Minidsp/Acoustic Elegance/DIYSG Volt8/DIYSG Concentric8
Offline scrarfussi
  • Trade Count: (+24)
  • Quantum In Me Fuit
« Reply #2 on: October 15, 2016, 09:40:54 PM »
Is your pc set to. Dhcp
suum cuique pulchrum est
"Then Said my heart here will i take my rest."
Offline ingenieus
« Reply #3 on: October 15, 2016, 09:44:56 PM »
Compare the network settings on the two PCs.
Offline sudyP
« Reply #4 on: October 16, 2016, 11:14:18 AM »
Thanks for the help. Tried both DHCP and static protocols and another PC. Seems to be a problem with the MS networking protocol or something. Xbox not registering on the network too. Going to try PC with a Linux Live USB to confirm.
Offline Mervin
  • Trade Count: (+62)
    • Security Audit and Control Solutions
« Reply #5 on: October 16, 2016, 11:42:56 AM »
Cannot be this difficult.  You using DHCP?  What is the scope?  how many IPs, any filtering?  Class of network?  DHCP is UDP 67/68 and a broadcast, must work.  post some detail ipconfig /all output on pc
Behind the cupboard door... Narnia
Offline sudyP
« Reply #6 on: October 16, 2016, 01:01:06 PM »
Thanks everyone, solved it. I had a loopback cable going from one port of the unmanaged switch to the other!!
Offline BWS
  • Keep calm and play Fortnite
« Reply #7 on: October 17, 2016, 07:54:40 AM »
This belongs here :point:
In the word : Scent, is it the S or the C that is silent?
Offline Danny Boy
« Reply #8 on: October 17, 2016, 08:15:43 AM »
I'm just throwing this out there........... You have to many cables  :coffee:
HT: Onkyo TX-NR828 | Wharfedale Obsidian 600 | Polk PSW350 | HiSense 60K390 | Zalman HD503 HTPC & Kodi 19.0
Stereo: NAD 3020i | NAD 522 | NAD T515 | Pioneer PL-512 | Technics SB-2170 | RPi 3, PiFi v2 & Moode Audio
Offline sudyP
« Reply #9 on: October 20, 2016, 07:14:36 PM »
That I do, that I do....
At least it got me a Legendary Thread on here :-)
