Author Topic: Leaving Feedback following a sale/purchase  (Read 3288 times)
Offline georgev
« on: June 23, 2010, 02:51:56 PM »
To the moderators:
Would you guys be able to start something like what they have on Audiogon, where you can leave feedback, both seller and purchaser? This makes it a safer place.
I think this is done also on Bid or Buy.
What do the rest think?
Offline Captain Ahab
Re: Leaving Feedback following a sale/purchase
« Reply #1 on: June 23, 2010, 02:55:53 PM »
Good idea
Offline Andrew
« Reply #2 on: June 23, 2010, 03:04:04 PM »
For the Classifieds section? You'd need to ask Kay if it's possible - he handles all the bits and bobs of the Forum from the operational side of things.
Don't judge me for being quiet - no one plans a murder aloud.
Offline georgev
« Reply #3 on: June 23, 2010, 03:46:07 PM »
Yup, for the classifieds section. Is this the wrong place for this thread? If so would you move it?
Offline Andrew
« Reply #4 on: June 23, 2010, 03:48:22 PM »
Egad, I may destroy it by accident. If I do, I'll email Kay and tell him about the request, though.
Offline kay
  • Site Owner
  • Total likes: 3
  • Computer geek
    • My Blog
« Reply #5 on: June 23, 2010, 03:55:26 PM »
Hey guys - moved it to site discussion, I think it's the most appropriate :)
I have looked into this, there are add-ons that create entire online market places which are much better than posting individual threads. I haven't so far found one which is good enough and compatible with the existing forum software (SMF) but these things change over time, so definitely worth another look.
I'll keep you posted.
Offline georgev
« Reply #6 on: June 24, 2010, 11:07:55 AM »
Thanks, would be great. When buying used from far and not being able to inspect, it helps. Otherwise I have had to get people I know to inspect.
Offline Gerlach
  • Total likes: 145
  • Far Far away there was a land that was far away.
« Reply #7 on: November 11, 2016, 06:39:54 AM »
Morning guys. Maybe someone can Help. I want to Leave feedback on someone profile but it seems to me I cant click on the positive and type my review. Can some just sent me the link of the steps.
I'm part of a cycling forum , Thehubsa "go check it out the setup there"  ;), It's click click and type your review and click and there you go.
Offline naughty
« Reply #8 on: November 11, 2016, 08:38:11 AM »
come guy - its just as easy here too ..... under all the stats it clearly states submit feedback for "XYZ" here
see the pic if it helps - the bit you are looking for is encircled in red to make it even easier  ;)
once you click on that you can submit your positive (or negative) feedback regarding your transaction in this particular form .... please select the correct options from the drop down menus regarding whether you are the seller or the buyer and whether your feedback is positive or negative, and you can provide a link to the sale thread, as well as provide long and short comments on how good/bad a trader a person is
  • Trade Count: (+140)
  • Total likes: 514
  • Cape Town Hi-Fi Club - get better sound
« Reply #9 on: November 11, 2016, 08:39:16 AM »
You can leave a positive score any time, this is how
Read the post relating to sale or offer that was made (suggest in the Classified's section), ie  http://www.avforums.co.za/index.php/topic,59109.0.html
Click on the name of the poster.  Another window opens
In the centre, second from the bottom, is a prompt "Submit feedback for xxxxx"
Click on this
Chose buyer, seller, or trade
Choose positive or negative
Write some suitable words
For the topic URL, you can leave that blank or copy and paste the link above
Click "Submit feedback"
The poster then receives an email telling him you have submitted feedback
  • Trade Count: (+30)
  • Total likes: 358
« Reply #10 on: November 11, 2016, 10:41:37 AM »
Or simply click on the figure after "Trade Count:" below the person's name, then scroll down, click on "Submit feedback for xxx". Finish as described above.
Offline Gerlach
  • Total likes: 145
« Reply #11 on: November 11, 2016, 11:49:36 AM »
Super Thanks guys and thanks for the help!! :pleasant: Sorted and did my Click click. Love to use this sort of system, we use it on our cycling forum and works really good.
