Author Topic: Downtime 2015/08/20  (Read 4804 times)
Offline kay
  • Site Owner
  • Total likes: 17
  • Computer geek
    • My Blog
Downtime 2015/08/20
« on: August 20, 2015, 12:07:32 PM »
Well this is embarrassing! The server ran out of free disk space causing MySQL to block. It looks like a moderator might have tried to update some settings in this state, which caused a config file to be wiped and delaying recovery. On the plus side, I managed to run a proactive repair on all the MySQL tables while the site was down.
I am aware that a number of niggles still exist after the 2.0.10 forum upgrade. I will attend to these soon.
Corrective actions: I've made sure that two independent alerting mechanisms exist that will get my attention. One got removed when I upgraded my phone, and one was that Gmail marked an alert as not important, and I saw it with about 2 hours delay.
Offline skollie
  • R.I.P.
  • Total likes: 3
  • Cableth make no differenth. Ith all in the plugth.
    • Blue Angel
Re: Downtime 2015/08/20
« Reply #1 on: August 20, 2015, 12:27:27 PM »
I had a bit of a problem about 30mins ago trying to access AVFSA as nothing happened. Reboot didn't help and eventually I found I was logged-in as a 'GUEST'. Resetting my password was required and all is well again.
Thanks Kay ;D
skollie
If you don't like my principles, I have others - Groucho Marx
