OK, I have elaboratd about my setup in fragmented fashion all over the place, but I'll outline it here for completeness.
My main goal was having a platform that can be used to measure various things, not just room modes. So, I did go all out when purchasing hardware, so it'll maybe exlude it from your list Alan, but may be of use to others. Anyway, I wanted the ability to measure speakers, amplifiers and other bits of audio hardware. So, this setup needed to be quite universal and semi-portable as well.
Hardware:
- M-Audi Firewire 410 Audio Interface. This can also supply phantom power to the mic
- ECM8000 measurement Mic
- Breakout box for speaker measurement with all the loopback capabilities for the measurement reference
- Breakout box for audio hardware measurements with attenuators
Software:
- Sound Easy V14 - Measuring speakers and Rooms
- RMAA Pro for doing distortion measurements
With the rig above I'm pretty much set to measure anything audio related and with the software/hardware I'm pretty much guaranteed of making distortion measurements down to around -110dB.
Just a note on measurement software. I understand that a lot of the freebie stuff uses swept sinewaves to perform measurements. This is the easy way, but is prone to contamination from adjacent signal sources. A better way is to use MLS based systems. This limits contamination of other signal sources affecting the measurements.
Like I said before, this configuration may not apply to you Alan, as it is pretty expensive. But, I noted it here for reference. Also, If you just want to make casual measurements on your room, you welcome to borrow it and this offer stands for anybody else in the JHB are.
Cheers
Gert
