Planning a speaker build, but need a valve amp to compliment
Tbot
Somerset West
The approach is simple.  I bought some Goldman Axiom 201's.  Not sure if they are 8 or 16 ohm.  The decal does not indicate what I am dealing with.  I know they can handle 15W max.  The idea is to build some form of backloaded horn style cabinet.
Back to the valve amp.  I would like to  understand the impact of 8 ohms against 16 ohms on a valve amp.  That should help me make a decision what to look for or what to ask for in the wanted section.
Thank you
Thinus
