Loudspeaker Material Suppliers - Cape Town
nubble
Hi,
I've decided to go down the road of DIY loudspeakers, and want to get together a list of material suppliers in Cape Town. Suppliers that dont mind DIY quantities, superb service and appropriately priced for their supplies.  :thumbs:
If their arent any Cape Town suppliers then za would do also, and then if that fails the preferred global supplier.
Can anyone recommend suppliers in Cape Town for any of the following categories:
- Wood for loudspeakers - MDF and birch plywood or other - various thickness with cutting service
- terminal plates/ binding posts
- spikes/feet
- port tubes
- acoustic treatment-damping
- speaker grill/cloth
- gasket caulk
- glues/screws/nuts/bolts
- finishing materials/ coverings
-drivers/ kits
- crossover components and design service
Im pretty certain that many DIY loudspeaker designers have gone through this exercise and would like to leverage that instead of re-invent the wheel.
thanks in advance
