Author Topic: Sound Proofing a Door  (Read 3490 times)
Offline Katji
    • soundcloud
Re: Sound Proofing a Door
« Reply #15 on: October 13, 2017, 10:34:16 AM »
This flat I'm currently staying in, there is just one problem. It bugs me. Person in flat above, I think, is tapping rhythmically; sometimes at like 4:30am, the other night at about 7:30pm.  I don't know what to do, how to tell him he needs to fix the bed or whatever it is. Thought about putting a notice/message in the lift.  :???:
#SPOTIFYMUSTFALL
Offline AlleyCat
« Reply #16 on: October 13, 2017, 11:13:48 AM »
^ Dear Doctor Ruth, or is Dr Ken Kassler today?].....
This flat I'm currently staying in, there is just one problem. It bugs me..........
"Not everything meaningful is measurable, and not everything measurable is meaningful" - Floyd Toole
Offline AlleyCat
« Reply #17 on: October 13, 2017, 11:15:09 AM »
This is a good thread.
Seriously, dude, treat the whole room! Treating the doors alone is not going to help you.
And stay away from the screamers louder tannoys, or buy decent pillows as suggested above, just make sure you don't smother them [too much].
And here we thought we have real hifi problems, cable threads are boring. Way to go Byron!
Offline Gerlach
« Reply #18 on: October 13, 2017, 11:44:26 AM »
And stay away from the screamers, or buy decent pillows as suggested above, just make sure you don't smother them [too much].
HAHAHAHAHAHA!!!! :ROFLMAO: :point: :ROFLMAO: :point: :ROFLMAO: :point:
Just spilled my Coffee!!!
Offline Gerlach
« Reply #19 on: October 13, 2017, 11:50:58 AM »
HAHA!! Sounds like a friend of mine, where his neighbour ask him one morning out side his apartment if they can just moved the Headboard of the bed away from the wall  :ROFLMAO:
Offline B_Unit
  • I am always looking for Vintage Marantz equipment
« Reply #20 on: October 14, 2017, 01:53:07 AM »
Gentlemen !
Here is the Door in question.
Here is the amount of depth we can work with roughly 48 cm.
Ill post more text tomorrow its a bit late now, Cheers for all the feedback though.
Regards
Byron
Offline CAD
  • Trade Count: (+61)
« Reply #21 on: October 14, 2017, 08:03:33 AM »
This thread is heading for Legendary Status.
A good read this morning  :giggle:
The way of the warrior is NO match for the way of the wife.
Offline Rodney_gold
  • R.I.P. 5 June 2018
  • Trade Count: (+13)
« Reply #22 on: October 14, 2017, 09:50:53 AM »
Roon/tidal > Squeezebox touch> Trinnov St2 >2x Devialet D premiers>  Vivid audio Giya G1 spirits ..fully treated room
Offline Steerpike
  • Forum Moderator
    • Toybox
« Reply #23 on: October 14, 2017, 09:08:41 PM »
Lots of comments, and nothing on real soundproofing yet!
The most important bit is getting it air-tight. The bulk of the 'partition' that you use can be something like chip-board, or even another door if you can find a cheap secondhand one. A double layer partition is way better than a single.  Then you need to seal all around it in a totally air-tight manner - mattress foam isn't the best. Pool Noodles are probably good, being closed cell.
If there are other paths for sound, like through the ceiling, or via a suspended floor, it might not be worth spending too much on sealing the door.
Another option:
Offline CAD
« Reply #24 on: October 14, 2017, 10:59:48 PM »
Cheapest or most cost effective option  :nfi:
Offline Scubadude
  • Trade Count: (+36)
  • Depressed? Cans on, volume up, ignore the world!
« Reply #25 on: October 15, 2017, 09:13:53 PM »
Disclaimer: No hamster was hurt in the making of this thread.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Offline Hi-Phibian
  • Trade Count: (+40)
    • Croak Audio Exploration
« Reply #26 on: October 16, 2017, 06:19:40 AM »
Disclaimer: No beaver was hurt in the making of this thread.
Fixed.
Proprietor of Croak Audio Exploration.
Fair, not crazy, cash paid for turntables and tonearms from Rega, Linn and Thorens.          http://www.croak.co.za
Offline CAD
« Reply #27 on: October 16, 2017, 07:10:47 AM »
^^^  :giggle:
Offline d0dja
« Reply #28 on: October 16, 2017, 07:39:17 AM »
He's not kidding. The key is air-tight. Any gaps will let sound through.
Duct tape the door all around the edges. Then get a big piece of drywalling (rhinolite?) cut to fit as exactly as possible into frame , duct tape that too. If you can, put isotherem tightly into that cavity (na gaps!).
That will sound proof extremely effectively.
Alternatively, learn tantra.
Like Sting.
Offline Danny Boy
« Reply #29 on: October 16, 2017, 09:27:20 AM »
Yeah, 10cm on a 5m roll will go a looong way
HT: Onkyo TX-NR828 | Wharfedale Obsidian 600 | Polk PSW350 | HiSense 60K390 | Zalman HD503 HTPC & Kodi 17.3
Stereo: NAD 3020i | NAD 522 | NAD T515 | Pioneer PL-512 | Technics SB-2170 | RPi 3, PiFi v2 & Moode Audio
