croak
R.I.P. 28 June 2021
- Joined
- Mar 28, 2007
- Messages
- 14,317
- Reaction score
- 939
Bo!ng
Fully sprung audio isolation solutions from Funk.
For years cables have tried to clean our electrical signals. But what have
we been doing about the interference caused by the extraneous mechanical
vibration all around from speakers or traffic from cars and floors? Feeding
straight back to your stylus, it negatively affects Pace, Rhythm and Timing.
This is really bad news as all rigid turntables are negatively affected this
way.
All the while, however, the very best decks are all isolated. Makes you
think.
So, if you have a rigid turntable, shouldn't yours be isolated?
Bo!ng is Funk's new decoupling solution that helps your deck into the high
end. Utilising springs that have been tuned very low and have a long travel,
you simply replace the existing feet of your turntable. (Relevant hardware
is included)
The benefits are real and easy to hear: your listening window opens wider
than ever.
Your Rega, Project, VPI, Clearaudio etc. will never have sounded so good.
Bo!ng is just about the most affordable, most definitive upgrade you can
make.
(If you want to lift the veil on your system even more? Partner it with
Achromat)
Bo!ng has solutions for amplifiers, CD players. (Speakers solutions: Spring
2016.)
If removing feet isn't an option, Kinetik Kradle is Funk's platform support.
Based on
Bo!ng with which to sit your component on, it too is again available Spring
2016.
Bo!ng is configurable: If one side very heavy, a heavy transformer, say, you
can compensate for this as well.
way.
think.
is included)
than ever.
make.
Achromat)
2016.)
Based on
2016.
