Is it dangerous to use an angle grinder to cut fiberglass?
  • Thread starter Swindlehurstguy
  • Start date
S
Swindlehurstguy
Guest
can someone shed some light here....no pun intended. I am removing a bath In order to convert one of our bathrooms into a laundry room. The bath however is proving to be more than a worthy adversary, soooo, could I use an angle grinder along the rear and side of the bath to cut through it in order to unseat the bath, so I can at least get it out of the way? I don't want to take any major risks but think if I can do that it would make getting it out much easier? Any recommendations? Thanks
B
