2 CHANNEL & 5 CHANNEL ON A THULE POWERAMP - HOW?
PAPPA3
Randfontein, West rand
I'm about to send this off, but I've never personally used all the functions.  A Thule PA250 B Power Amp.  I understand that there is a switch on the front panel which allows one to use either it in either a 2 channel or 5 channel mode.  The amp has 2 channel inputs via rca or via balanced connections.  It has a separate set of inputs taking a 5 inputs via rca's.  There are 5 speaker terminals.  I tried connecting the outputs of my onkyo txnr 808 to the 2 channel rca inputs on the power amp, but even if I push the 2 channel button on the front, there is no signal.  If i connect the outputs to the left and right main speaker inputs in the 5 channel input section there is sound.  Anyone know why I can't get sound from the 2 channel input section?
The amp is rated as
5 x 100 watt into 8 ohms
2 x 250 watts into 8 ohms
5 x 150 watts into 4 ohms
2 x 380 watts into 4 ohms
How do I get 2 x 250 watts?  Does the amp output this automatically when it does not detect signals from the other 3 inputs?
BROCHURE: http://www.fullcompass.com/common/files/4711-PA250B.pdf
REVIEW: http://www.tnt-audio.com/ampli/thule250_e.html
MANUAL: http://sidekick-audio.com/media/upload/file/PR250Bum%20.pdf
