Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Subwoofer choice for noob
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Enigma_2k4" data-source="post: 38784" data-attributes="member: 631"><p>As Genotan's signature says: "No replacement for displacement" - I echo his sentiment completely. A big 15 in the right box will get really low and rumble really nicely! I won;t have to work as hard to get the results you want.</p><p></p><p>Also, I suggest you check out this thread:</p><p><a href="http://www.avforums.co.za/index.php/topic,2330.0.html" target="_blank">http://www.avforums.co.za/index.php/topic,2330.0.html</a></p><p></p><p>Here Metalmilitia used 2 x 15" car subs to great effect in his home setup. You could easily do the same with just 1. I have also heard car subs being used in home setups and have always left feeling very impressed. Car equipment generally has to be more forgiving then home stuff by the nature of their requirements so it might integrate alot better.....?</p><p></p><p>Also, you cannot faulter that "I did it myself" feeling!</p></blockquote><p></p>
[QUOTE="Enigma_2k4, post: 38784, member: 631"] As Genotan's signature says: "No replacement for displacement" - I echo his sentiment completely. A big 15 in the right box will get really low and rumble really nicely! I won;t have to work as hard to get the results you want. Also, I suggest you check out this thread: [url=http://www.avforums.co.za/index.php/topic,2330.0.html]http://www.avforums.co.za/index.php/topic,2330.0.html[/url] Here Metalmilitia used 2 x 15" car subs to great effect in his home setup. You could easily do the same with just 1. I have also heard car subs being used in home setups and have always left feeling very impressed. Car equipment generally has to be more forgiving then home stuff by the nature of their requirements so it might integrate alot better.....? Also, you cannot faulter that "I did it myself" feeling! [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
