Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Biamping using home theatre receivers
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="croak" data-source="post: 58500" data-attributes="member: 361"><p>Playing devils advocate here. I think to perfectly identical receivers could be made to work though with complications like splitting the sources to feed audio in to both amplifiers. As long as the remote eyes are close to eachother and the amps remain in sync it could actually work.</p><p>(I remeber a UK hifi show where 2 x Pioneer A400 integrated amps were used to bi amp a set of speakers, the volume controls were "ganged" with an elastic band!!!)</p><p></p><p></p><p>However, I think I understand the OP uses more then one set of front speakers at the same time and despite previous posts where we suggested he tries better single pair speakers this seems to be the way he likes things. so rather than bi amping by splitting the crossovers, running a "power amp" section per loadspeaker pair will give more control.</p><p></p><p>IOW, if you do use a receiver with pre outs with a separate power amp, use the receiver to drive the smaller speakers completely and the power amp to drive the bigger ones. It should increase SPL, control AND SAFETY for the amplifiers.</p></blockquote><p></p>
[QUOTE="croak, post: 58500, member: 361"] Playing devils advocate here. I think to perfectly identical receivers could be made to work though with complications like splitting the sources to feed audio in to both amplifiers. As long as the remote eyes are close to eachother and the amps remain in sync it could actually work. (I remeber a UK hifi show where 2 x Pioneer A400 integrated amps were used to bi amp a set of speakers, the volume controls were "ganged" with an elastic band!!!) However, I think I understand the OP uses more then one set of front speakers at the same time and despite previous posts where we suggested he tries better single pair speakers this seems to be the way he likes things. so rather than bi amping by splitting the crossovers, running a "power amp" section per loadspeaker pair will give more control. IOW, if you do use a receiver with pre outs with a separate power amp, use the receiver to drive the smaller speakers completely and the power amp to drive the bigger ones. It should increase SPL, control AND SAFETY for the amplifiers. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
