AVForums South Africa
September 10, 2010, 08:49:09 am *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: New domain name, new forum software - welcome to the upgraded AVForums!
   Home   Help Search Login Register
Pages: 1 [2]
  Print
Author Topic: Speaker's impedance  (Read 545 times)
Neil
Member
My current baby!
View Profile
« Reply #15 on: July 16, 2010, 02:20:05 pm »
yes you right, but i'm sure some also had impedance switches? anyway not serious, i dont believe in gimmick switches though, my opnion
Logged
1996 onkyo stereo system
2003 - till now Yamaha RXV-450
alphabet
Extra Boards
Flying High, Digging Low
View Profile
« Reply #16 on: July 16, 2010, 02:26:21 pm »
Totally agree. I like them such as on my stereo setup - On/Off/Volume, Input selector Wink
Logged
My short-term memory is not as sharp as it used to be;
Also, my short-term memory is not as sharp as it used to be!
(Location Cape Town)
_________________________
ludo
Hero Member
View Profile
« Reply #17 on: July 16, 2010, 08:17:13 pm »
Tony, the impedance switch affects the power transformer. Usually connecting different taps on the secondary windings used for the power amp section.
Speakers of the same sensitivity (say 88dB/Watt/meter) would produce the same SPL if the power input to both is the same. Whether they be 4 Ohm or 8 Ohm units. But to get to that same power and SPL level, the 4 Ohm unit will require 3dB (about 30%) less voltage on its input terminals.
So if you want the same power available, you can relax the supply voltage to the amplifier by almost 30% when using the 4 Ohm speaker. This will have a good effect on the power amplifier section, as less voltage sitting across the output stage will heat up the amplifier less.
Semiconductors have only two enemies. Heat and voltage**. So less voltage and less heat is better for the longevity of the amplifier. If you're kind of green-minded, it's better for wasting less energy too.
So if you are never requiring the extra voltage in use with your 6 Ohm speakers, there is no point in having it there. If the amp sounds good with the 4 Ohm setting, use the 4 Ohm setting. By all means use the 4 Ohm setting even in the unlikely event that you find a weird pair of 16 Ohm speakers to connect, IF it sounds good.
If the amp ever clips or just sounds "stressed" on the loudest passages that you play, then use the 8 Ohm setting for a higher supply voltage. It would be the lesser evil in that case, IF it brings about an audible improvement. Higher voltage will not of necessity sound better. There are very many factors involved.
The objective of this switching is to extend the life of the amp and to protect your pocket. While it is very possible to build an amp that is both extremely powerful and perfectly reliable with all reasonable loads, you may be pleased that you don't have to pay for it. Especially if it is a multichannel amp.
**Beer and wine inside the amp are also enemies. Beer and wine inside the owner initially get "transformed" to voltage and heat inside the amp by a complex Math usually referred to as the "Homer Transform" which splits the emotional domain from the physical domain for analysis, much like Fourier Transform splits the time domain from the frequency domain. Imaginary numbers become misunderstood benefits etc. Wink
Logged
If it 's going vrot, put it on the buffet ! - Fats
Moog
Member
View Profile
« Reply #18 on: July 17, 2010, 07:09:10 pm »
 ::)I have used amps with impedance switches before. In my opinion (not being an audio designer/engineer) i think the switch is there for a good reason. The last amp that i used with this feature was a Sansui AUG77X and that was way back in 1986. According to the manual spec sheet, it was rated at 110 watts per channel into 8 ohms and 320 dynamic watts into 2 ohms. What i noticed was that at high level listening and fed into a pair of Marantz HD900 speakers with a nominal impedance rating of 8 ohms, the amp would dissipate more heat with at the 8 ohms setting than at the 4 ohms setting.Therefore with this speaker, i could play this amp at party volumes at the 4 ohm setting for the whole day if chose to. However,at lower listennig levels, i do not think it matters whether you switch to 8 ohms or 4 ohms.
Logged
Pages: 1 [2]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Google visited last this page September 06, 2010, 02:11:20 pm
